Deploy an Edge Spoke Gateway on Aviatrix Edge Platform
This document provides instructions for deploying a primary and secondary highly available (HA) Edge Spoke Gateways on the Aviatrix Edge Platform.
Single VLAN connected to the Edge Gateway via a single vNIC.
Multiple VLANs connected to the Edge Gateway via a single vNIC (Trunk Port) and sub-interfaces for each VLAN.
VRRP on Edge Gateway.
LAN-side BGP.
Connectivity to single or multiple Transit Gateways from Edge Gateway.
Before you deploy an Edge Spoke Gateway on the Aviatrix Edge Platform, ensure the prerequisite steps are complete.
Create the Primary and Secondary Edge Spoke Gateway (Aviatrix Edge Platform)
Follow the steps below to create and deploy a primary and secondary highly available (HA) Edge Transit Gateways on the Aviatrix Edge platform.
This diagram provides a high-level view of the process for deploying Edge Spoke Gateway using Aviatrix CoPilot.
Step 1: Gateway Configuration
In Aviatrix CoPilot, go to Cloud Fabric > Hybrid Cloud > Edge Gateways > Spoke Gateways tab.
Click + Spoke Gateway, then provide the following information.
A name for the Edge Gateway.
The platform account where you want to deploy the Edge gateway.
Identifies the edge location.
The high availability mode.
On (Active Standby Mode) enables Edge gateway connection with one active peering and one standby peering. Only the active peering forwards network traffic. The network switches to the standby peering when the primary peering goes down.
Preemptive
Determines the network’s behavior when the primary gateway goes down.
Preemptive is applicable only when High Availability is set to On with Active Standby Mode. The Preemptive is set on the primary gateway.
On enables the network to automatically switch back to the primary gateway when the primary gateway connection is back up.
Off enables the network to continue to use the standby gateway even after the primary gateway is back up, until you initiate a manual switchover.
Primary Device
Secondary Device
The gateway size.
Small - 2 vCPU - 4GB
Medium - 4 vCPU - 8GB
Large - 8 vCPU - 16GB
X-Large - 16 vCPU - 32GB
In the Interface Configuration section, configure the WAN, LAN, and Management interfaces. By default, an Edge Spoke Gateway has three interfaces: one WAN interface on eth0, one LAN interface on eth1, and one Management interface on eth2. You will need these IP addresses to configure the interfaces.
If High Availability mode is selected, then configure both the primary and secondary Edge gateway interfaces.
Configure the WAN Interface
To configure the WAN interface:
Interface
IP Assignment
Configure the LAN Interface
To configure the LAN interface:
Interface
IP Assignment
VRRP
VRRP can be configured only if HA Edge Gateway is configured.
VRRP Gateway IP
You cannot edit the VLAN ID after the Edge Gateway is created. To edit the VLAN sub-interface attributes, it is highly recommended to delete and recreate the VLAN sub-interface configuration. Field
VLAN ID
The VLAN ID of the VLAN segment.
VLAN Interface CIDR
The VLAN IP address of the VLAN segment.
The Default Gateway IP address of the VLAN segment.
Sub-Interface Tag
Name to identify the VLAN segment.
When a secondary HA Edge Gateway is configured, the VLAN configurations that are shared between the primary and secondary gateway and are non-editable on the secondary gateway.
Configure the MGMT Interface
To configure the Management interface, click MGMT, then provide the following information.
Field |
Description |
Interface |
IP Assignment |
The MGMT interface defaults to DHCP. This setting cannot be changed. The Edge Gateway will automatically NAT out of the physical MGMT interface of the edge node when using the Aviatrix Edge platform. |
Private Network |
Leave this setting to Off. The Edge Gateway on the edge hardware requires public Internet reachability to connect to the Aviatrix Controller and Aviatrix Edge infrastructure in the cloud. |
Egress CIDR (Primary) |
The Egress CIDR is the public IP address which the Management interface uses. If the Public IP is used from Edge Gateway Management interface to establish connectivity to Aviatrix Controller, then configure the Public IP as the CIDR. The CIDR is then added to the Controller security group to allow incoming traffic from the Edge Gateway. |
Egress CIDR (Secondary) |
The Egress Public IP for the secondary Edge Gateway’s Management interface when High Availability is configured. |
Step 3: Interface Mapping
The table shows a mapping of the Edge Gateway’s logical interface names to the Edge Gateway’s Linux interface names. These interface names are used in the Aviatrx log files and error messages. When performing diagnostic or troubleshooting on the Aviatrix Platform, you can refer to this mapping for the interface name.
Field |
Description |
Interface |
Next Steps
For hybrid, multicloud, or LAN-side connectivity, you can attach the Edge gateway to multiple Aviatrix gateways. See Edge Gateway Attachments.
For remote site connectivity, you can connect the Edge gateway to remote devices. See Edge Gateway External Connection.
