Create the Primary Edge Transit Gateway cloud-init ZTP file
To create the Edge Transit Gateway cloud-init ZTP file, follow these steps.
Step 1: Gateway Configuration
Click Transit Gateways, then click + Transit Gateway.
In the Gateway Configuration page, provide the following information.
A name for the Edge Gateway.
The platform account where you want to deploy the Edge gateway.
Identifies the edge location.
ZTP File Type
This is set to cloud-init.
High Availability is set to Off for the primary Edge gateway.
You can turn High Availability to On after the primary Edge gateway is created.
You can configure multiple WAN interfaces on the Edge gateway. Megaport MVE supports a maximum of 5 interfaces. Aviatrix Edge Transit Gateway requires at least one WAN and one MGMT interface, additional three interfaces can be WAN interfaces.
Configure the WAN Interface
In Interface Configuration page, click WAN and provide the following information.
Interface
Adding multiple WAN interfaces is applicable when the Edge Gateway is set up for BGP underlay to cloud service provider (CSP) or other Edge Transit Gateways. Add an interface per CSP underlay (such as Direct Connect or Express Route).
Interface Secondary CIDRs
Password (optional)
The MD5 authentication key.
In Gateway Configuration field, enter the Local AS Number of the local Edge Gateway.
To configure the Edge Transit Gateway Management interface:
In Interface Configuration page, click MGMT.
Leave the Private Network setting to Off. In Megaport, the MGMT interface of the Edge Transit Gateway is assigned the public IP address that is allocated by Megaport.
If a required WAN or MGMT field is missing, the interface tab is highlighted to indicate there is an error.
Step 3: Interface Mapping
The table shows a mapping of the Edge Gateway’s logical interface names to the Edge Gateway’s Linux interface names. These interface names are used in the Aviatrx log files and error messages. When performing any diagnostic or troubleshooting on the Aviatrix Platform, you can refer to the mapping for the interface name.
Field |
Description |
Interface |
Click Done to create the ZTP cloud-init image file. CoPilot downloads the ZTP cloud-init file to your downloads folder.
The cloud-init file is valid for 24 hours after you create it, so you must launch an Edge VM and deploy the Edge Gateway on your MVE platform within that time. You will not be able to download the cloud-init file again and will have to recreate a new file. |
Field |
Description |
Name |
A name for the Edge Gateway. The name must start with a letter and contain only letters, numbers, and dashes (no special characters or spaces) and it can be up to 50 characters long. |
Platform |
The platform account where you want to deploy the Edge gateway. You can create and edit platform accounts in CoPilot by going to Cloud Fabric > Hybrid Cloud > Platforms tab. |
Site |
Identifies the edge location. You can select an existing name or enter a new name for the edge location. |
ZTP File Type |
This is set to cloud-init. |
High Availability |
High Availability is set to Off for the primary Edge gateway. You can turn High Availability to On after the primary Edge gateway is created. |
WAN Interface
You can configure up to 9 WAN interfaces on the primary Edge Gateway.
Field |
Description |
Interface |
Add an interface per CSP underlay (such as Direct Connect or Express Route). When Edge Gateway is not terminating CSP underlay, use one interface per Edge Gateway to connect to upstream router. |
Interface Labels |
A name to identify the WAN interface. |
BGP |
Enables BGP underlay connection to cloud service provider (CSP) or other Edge Transit Gateways on the WAN interface. Set BGP toggle On to set up BGP connection to cloud routers such as VGW, VNG, and Google cloud router.
Interface Primary CIDR |
The CIDR for the WAN interface. DHCP for dynamic IP address assignment is not supported.
If you need to create a BGP underlay connection to cloud service provider (CSP) with a link-local IP address, you must enter the link-local IP address in the Link-local Underlay CIDR setting of the WAN interface. |
Interface Secondary CIDRs |
The secondary CIDRs for the WAN interface. Interface CIDR must be in the format interface_ip/netmask (for example, 192.18.20.1/24). The secondary CIDRs are used for High Performance Encryption (HPE) attachment peering connections over a private network between the Edge Transit Gateway to another Edge Transit Gateway or Edge Spoke Gateway. The secondary IP addresses (based on the secondary CIDRs) are automatically assigned to create the peering connections. You can define /32 CIDR for specific secondary IP address.
Default Gateway IP |
The Default Gateway IP address for the WAN interface. For CSP underlay, this is the remote side IP address of the BGP session on CSP VNG or VGW. If Link-Local Underlay CIDR is configured, the Default Gateway IP should be in the same subnet as the Link-Local Underlay CIDR, otherwise, it should be in the same subnet as the WAN Interface CIDR. |
WAN BGP
Field |
Description |
Local ASN |
The Local AS Number of the Edge Gateway. |
Remote ASN |
The AS Number of the CSP side peering connection such as private VIF on VGW (AWS) and VNG ASN (Azure). |
Local LAN IP |
The IP address of the Edge Gateway. This is the local peering PTP IP for BGP. |
Remote LAN IP |
The IP address of the CSP VNG or VGW peering PTP IP. (GCP is not supported). |
Password (optional) |
The MD5 authentication key. |
MGMT Interface
Field |
Description |
Interface |
Private Network |
Leave Private Network setting to Off. In Megaport, the MGMT interface of the Edge Transit Gateway is assigned the Public IP address that is allocated by Megaport. |
Egress CIDR (Primary) |
The Egress CIDR is the public IP address which the Management interface uses. This is the Public IP of the Edge VM assigned by Megaport, which can be obtained once Megaport Internet VXC is connected to the MGMT interface of the Edge Gateway. The CIDR is then added to the Controller security group to allow incoming traffic from the Edge Gateway. |
Interface Mapping
Interface Mapping shows how the Edge Gateway’s logical interface names maps to the Edge Gateway’s Linux interface names. These interface names are used in the Aviatrx log files and error messages. The mapping is provided for your reference when performing any diagnostic or troubleshooting on the Aviatrix Platform.
Field |
Description |
Interface |
