Deploy an Edge Transit Gateway on the Aviatrix Edge Platform
This document provides instructions to deploy a primary and secondary highly available (HA) Edge Transit Gateways on the Aviatrix Edge platform.
The following diagram shows an example of network connectivity for Edge Transit Gateway to Transit Gateways in the cloud and Edge Spoke Gateways at remote sites.
Before you deploy an Edge Transit Gateway on the Aviatrix Edge Platform, ensure the prerequisite steps are complete.
Create the Primary and Secondary Edge Transit Gateway (Aviatrix Edge Platform)
Follow the steps below to create and deploy a primary and secondary highly available (HA) Edge Transit Gateways on the Aviatrix Edge platform.
Step 1: Gateway Configuration
Click + Transit Gateway, then provide the following information.
A name for the Edge Gateway.
The platform account where you want to deploy the Edge gateway.
Identifies the edge location.
The high availability mode.
Off creates only the primary Edge gateway with one active peering.
On (Active Active Mode) enables Edge gateway connections with all active peerings to perform load sharing and forward network traffic.
Primary Device
Secondary Device
The gateway size.
Small - 2 vCPU - 4GB
Medium - 4 vCPU - 8GB
Large - 8 vCPU - 16GB
X-Large - 16 vCPU - 32GB
In the Interface Configuration section, configure the WAN and Management interfaces. By default, an Edge Transit Gateway has two interfaces: one WAN interface on eth0 and one Management interface on eth2. You will need these configuration information to configure the interfaces.
If High Availability mode is selected, then configure both the primary and secondary Edge gateway interfaces.
Configure the WAN Interface
Edge Transit Gateway on the Aviatrix Edge Platform supports up to 4 WAN interfaces.
Interface
Adding multiple WAN interfaces is applicable when the Edge Gateway is set up for BGP underlay to cloud service provider (CSP) or other Edge Transit Gateways. A maximum of four WAN interfaces per Edge Gateway is supported.
IP Assignment
Interface Secondary CIDRs
The Local ASN Number of the Edge Gateway.
Password (optional)
The MD5 authentication key.
If BGP is turned On, in Gateway Configuration, enter the Local AS Number of the local Edge Gateway.
In Interface Configuration, click MGMT, then provide the following information.
Interface
IP Assignment
Private Network
Leave this setting to Off.
Egress CIDR (Primary)
Egress CIDR (Secondary)
Step 3: Interface Mapping
The table shows a mapping of the Edge Gateway’s logical interface names to the Edge Gateway’s Linux interface names. These interface names are used in the Aviatrx log files and error messages. When performing diagnostic or troubleshooting on the Aviatrix Platform, you can refer to this mapping for the interface name.
Field |
Description |
Interface |
Backup Peering
If the Edge Gateway is deployed in Active-Active high availability mode:
In Backup Peering, select a WAN interface to use to establish the attachment peering between the primary and HA Edge Gateway.
Click Done to create the primary and HA gateways.
Next Steps
For hybrid, multicloud, or LAN-side connectivity, you can attach the Edge gateway to multiple Aviatrix gateways. See Edge Gateway Attachments.
For remote site connectivity, you can connect the Edge gateway to remote devices. See Edge Gateway External Connection.
