Static Policy-Based (Unmapped) External Connection (Terraform Example)
Connect to a remote site that supports policy-based VPN connectivity with static configuration (unmapped) from an Aviatrix gateway.
Currently, Aviatrix CoPilot does not offer an option to create Static Policy-Based Unmapped connections through its UI.You can create Static Policy-Based Unmapped connections by using the Aviatrix Terraform Provider, instead. This document describes how to create a Static Policy-Based Unmapped external connection using the Aviatrix Terraform resource, aviatrix_site2cloud.
Supported Gateways
Spoke Gateway that is not BGP enabled in AWS, Azure, and GCP
Speciality Gateway (not applicable to Public Subnet Filtering Gateway)
External Connection Settings
For information about the options that you can configure for a Site2Cloud (S2C) external connection, refer to About External Connection Settings.
Terraform Script
terraform {
required_providers {
aviatrix = {
source = "AviatrixSystems/aviatrix"
version = ">= 3.1.0"
provider "aviatrix" {
controller_ip = var.controller_ip
username = var.username
password = var.password
variable "controller_ip" { type = string }
variable "username" { type = string }
variable "password" { type = string }
variable "local_gw_name" { type = string }
variable "remote_gw_ip" { type = string }
variable "local_subnet_cidr" { type = string }
variable "remote_subnet_cidr" { type = string }
resource "aviatrix_site2cloud" "policy_based_unmapped" {
connection_name = "policy-based-unmapped"
vpc_id = aviatrix_gateway.local.id
primary_cloud_gateway_name = var.local_gw_name
remote_gateway_type = "generic"
tunnel_type = "policy"
connection_type = "unmapped"
remote_gateway_ip = var.remote_gw_ip
local_subnet_cidr = var.local_subnet_cidr
remote_subnet_cidr = var.remote_subnet_cidr
Terraform Variable Keys and Descriptions
| Key | Description |
controller_ip |
Aviatrix Controller IP or FQDN. |
username |
Aviatrix Controller username. |
password |
Aviatrix Controller password. |
local_gw_name |
Name of the local Aviatrix gateway. |
remote_gw_ip |
Public IP address of the remote device. |
local_subnet_cidr |
Local subnet CIDR block (for, example, 10.0.0.0/16). |
remote_subnet_cidr |
Remote subnet CIDR block (for example, 192.168.0.0/16). |
For a list of the supported resource arguments, refer to aviatrix_site2cloud.
