Creating the ZTP Cloud-Init for the Secondary Edge Gateway (Equinix)
  • Before you can create the secondary highly available (HA) Edge Gateway, the primary Edge Gateway must be deployed and its status must be Up.
  • When creating the HA Edge Gateway, the primary Edge Gateway cannot have BGP underlay or BGP over LAN external connections. This does not apply when multiple Edge Gateways are created in the same site without HA configuration.
  • Edge Gateway high availability on the Equinix Platform is supported on the latest Aviatrix Controller release version.
Step 1: Gateway Configuration
  1. Go to Cloud Fabric > Hybrid Cloud > Edge Gateways tab.
  2. Click Spoke Gateways
  3. In the table, locate the primary Edge Gateway for which you want to create the HA gateway and click its Edit icon.
  4. In Edit Edge Gateway, from the High Availability dropdown menu, select Active-Active or Active-Standby mode.
  5. Click Next to configure the edge gateway interfaces.
In Interface Configuration, configure the WAN, LAN, and Management interfaces of the secondary (HA) Edge Gateway.
Configuring the WAN Interface
To configure the WAN interface, click + WAN Interface, then provide the following information.
Interface
Adding multiple WAN interfaces is applicable when the Edge Gateway is set up for BGP underlay to cloud service provider (CSP).
Edge Gateway WAN support for BGP underlay to CSP is supported for AWS, Azure, and GCP.
Interface Primary CIDR
Password (optional)
The MD5 authentication key.
Configuring the LAN Interface
To configure the LAN interface, click LAN, then provide the following information.
Interface
  1. Click MGMT, then click + MGMT Interface.
  2. Leave the default settings and click Save.
    Leave the Private Network setting to Off. In the Equinix Platform, the Management interface of the Edge Gateway is assigned the public IP address that is allocated by Equinix.
  3. To create the ZTP cloud-init image file, click Done.
    CoPilot downloads the ZTP cloud-init file to your downloads folder.
    Next, log in to your Equinix Portal and deploy the Edge Gateway VM instance and attach the cloud-init image file to complete the Edge Gateway creation and authentication with the Aviatrix Controller.
    The cloud-init file is valid for 24 hours after you create it, so you must launch an Edge VM and deploy the Edge Gateway on the Equinix platform within that time. You will not be able to download the file again and will have to repeat the steps to recreate a new cloud-init file.
Step 3: Deploy the Edge Gateway in Equinix Network Edge
