SmartGroups Reference
Reference information about SmartGroups.
SmartGroups Overview Page Reference
Descriptions of fields and properties visible on the CoPilot SmartGroups overview/list page.
Items are listed in alphabetical order.
Field/Property names correspond to those used in the CoPilot user interface.
| Date | Description |
Name  |
Unique name for the SmartGroup.  |
Refetch CSP Resources  |
Retrieves the latest resource information from your cloud service providers (CSPs).  |
Resource Type  |
Network resources to be included as part of the SmartGroup. A resource type can be virtual machine, a subnet, or a VPC/VNet. A resource can be specified by the IP address or CIDR of the resource or specified matching criteria on any property for the resource type. Resource-type based SmartGroups are only supported on public AWS, Azure, and GCP clouds. Other clouds must use the IP address or CIDR to specify the resource.  |
Rule References (Distributed Cloud Firewall Only)  |
When using SmartGroups for Distributed Cloud Firewall (DCF), the number of DCF policies associated with the SmartGroup.  |
Create New SmartGroup Reference
Descriptions of fields and properties used in CoPilot for creating SmartGroups.
| Field/Property | Description |
IP Addresses/CIDRs  |
One or multiple IP addresses and/or CIDRs for the network resource(s) included in the SmartGroup.  |
Name  |
Preview Resources  |
Lists all resources available across your Aviatrix managed cloud networks.  |
Resources  |
One or multiple network resources to be included as part of the SmartGroup. A resource can be a virtual machine, a subnet, or a VPC/VNet. A resource can be specified by the IP address or CIDR of the resource or specified matching criteria on any property for the resource type. Resource-type based SmartGroups are only supported on public AWS, Azure, and GCP clouds. Other clouds must use the IP address or CIDR to specify the resource.  |
Resource-Type Subnet(s)  |
Subnet to be included in the SmartGroup as identified by the matching condition criteria.  |
Resource-Type Virtual Machine(s)  |
Virtual Machine to be included in the SmartGroup as identified by the matching condition criteria.  |
Resource-Type VPC/VNet(s)  |
VPC/VNet to be included in the SmartGroup as identified by the matching condition criteria.  |
