Metrics Monitored for Aviatrix Resources
The system metrics and network metrics that you can access in CoPilot are captured by the Aviatrix Controller. The Controller pulls the data from virtual machines (instances/hosts) that Aviatrix Gateways run on and feeds that data to CoPilot.
Some metrics can be used for triggering actions such as alerting and Gateway scaling. You can also use metrics to monitor the performance of Gateway hosts. You can monitor performance in CoPilot from the Monitor > Performance page.
In addition, with the Aviatrix Network Insights API add-on license, you can use APIs to analyze the performance and health of your Aviatrix-managed resources in external monitoring systems. See Monitoring with Network Insights API for information about using Network Insights Metric and Status APIs.
About Metrics that are Monitored for Aviatrix Resources
Aviatrix Controller captures system metric and network metric information about the virtual machines (instances/hosts) that Aviatrix Gateways run on.
Health-type metric information is also captured for Controller and CoPilot virtual machines. See Global Control Plane Health Alert.
Metrics that are monitored by Aviatrix Controller and Aviatrix CoPilot include the following:
On the CoPilot Monitor > Performance page, you can select metrics to monitor performance on your resource VMs.
On the CoPilot Monitor > Notifications > Alerts Configuration page, you can configure how to use the pre-existing set of metrics to send notifications about events that occur in your network, such as performance bottlenecks or other problems.
To better understand how notifications and alerts work and how to configure them in CoPilot, see documentation:monitoring-troubleshooting:user-alerts-network.adoc.
For more information about integrating Aviatrix metric and status APIs with external monitoring tools, see Monitoring with Network Insights API.
Health Metrics for Triggering Notifications or Other Actions
The following health metrics are available in CoPilot. They are listed in alphabetical order, by the name used in the CoPilot UI.
Name (Health Metric) Description Internal Metric Name Accessible by API
BGP Peering Status
Any BGP peering status change triggers an alert.
BGPpeeringStatus
Connection Status
Any connection status change on the specified gateways/connections triggers an alert.
ConnectionStatus
Gateway Status
Any gateway status change triggers an alert.
GatewayStatus
Underlay Connection Status
Monitors the syslog from any connection that includes the host as the source or destination. When syslog data indicates a potential problem from each direction of the connection between that host and another host within 30 seconds of the other, the alert is triggered. On the same connection, if the syslog data later indicates the problem is resolved from either direction, the alert is automatically resolved.
UnderlayConnectionStatus
System Metrics for Triggering Notifications or Other Actions
For Aviatrix Controller and Aviatrix gateways, you can configure alerts based on the following system metrics. Aviatrix gateways report live Linux system statistics (such as memory, CPU, I/O, processes, and swap) for the instances/virtual machines on which they run. Metrics are listed in alphabetical order, by the name used in the CoPilot UI.
Name (System Metric) Description Internal Metric Name Accessible by API
CPU Idle (%)
Of the total CPU time, the percentage of time the CPU(s) spent idle and waiting for tasks from the kernel.
cpu_idle
20
CPU Kernel Space (%)
Of the total kernel space memory on the host (VM/instance), the percentage of time spent running kernel code.
cpu_ks
20
CPU Steal (%)
Of the average CPU wait time on the host (VM/instance), the percentage of time a virtual CPU waits for a real CPU while the hypervisor services another virtual processor.
cpu_steal
CPU Used (%)
The percentage of CPU used.
cpu_used_per
CPU User Space (%)
Of the total CPU time, the percentage of time spent running non-kernel code.
cpu_us
20
CPU Wait (%)
Of the total CPU time, the percentage of time spent waiting for IO.
cpu_wait
20
Disk Free
The storage space on the disk (volume) that is free/unused.
hdisk_free
Disk Free (%)
Of the total storage space on the disk (volume), the percentage of storage space that is free/unused.
hdisk_free_per
Disk Total
The total storage space on the disk (volume).
hdisk_tot
IO Blocks In
The number of blocks received per second from a block device.
io_blk_in
IO Blocks Out
The number of blocks sent per second to a block device.
io_blk_out
Memory Available
The available amount of memory that can be allocated to new or existing processes.
memory_available
20
Memory Available (%)
Of the total memory, the percentage of the available memory that can be allocated to new or existing processes.
memory_available_per
Memory Buffer
The amount of memory used as buffers.
memory_buf
20
Memory Cache
The amount of memory used as cache.
memory_cached
20
Memory Swapped
If swapped is enabled, the amount of virtual memory used.
memory_swpd
20
Memory Total
The total memory.
memory_tot
Memory Used
The amount of memory used.
memory_used
Memory Used (%)
Of the total memory, the percentage of memory used.
memory_used_per
Processes Uninterruptible Sleep
The number of processes blocked waiting for I/O to complete.
nproc_non_int_sleep
Processes Waiting To Be Run
The number of processes that are running or waiting for run time.
nproc_running
Swaps From Disk
Memory that is swapped in every second from disk in kilobytes.
swap_from_disk
Swaps To Disk
Memory that is swapped out every second to disk in kilobytes.
swap_to_disk
System Context Switches
The number of context switches per second.
system_cs
System Interrupts
The number of interrupts per second, including the clock.
system_int
Network Metrics for Triggering Notifications or Other Actions
For Aviatrix Controller and Aviatrix gateways, you can configure alerts based on the following network metrics. Metrics are listed in alphabetical order, by the name used in the CoPilot UI.
Name (Network Metric) Description Internal Metric Name Accessible by API
Bandwidth Egress Limit Exceeded
bandwidth_egress_limit_exceeded
Bandwidth Egress Limit Exceeded (%)
per_bandwidth_egress_limit
Bandwidth Egress Limit Exceeded Rate
The number of tx packets dropped because the bandwidth allowance limit was exceeded.
This metric is supplied by the Elastic Network Adapter (ENA) driver only on AWS.
rate_bandwidth_egress_limit_exceeded
Bandwidth Ingress Limit Exceeded
bandwidth_ingress_limit_exceeded
Bandwidth Ingress Limit Exceeded (%)
The percentage of dropped rx packets due to exceeding the bandwidth allowance limit. This metric is specific to the ENA driver on AWS.
per_bandwidth_ingress_limit_exceeded
20
Bandwidth Ingress Limit Exceeded Rate
(AWS Only) Bandwidth Ingress Limit Exceeded Rate — The number of rx packets dropped because the bandwidth allowance limit was exceeded.
This metric is supplied by the ENA driver only on AWS.
rate_bandwidth_ingress_limit_exceeded
Collisions during Transmission
The count of collisions during packet transmission.
tx_colls
Collisions Rate during Transmission
The number of collisions per second during packet transmission.
rate_tx_colls
Compressed Packets Received
The count of compressed packets received.
rx_compressed
Compressed Packets Received Rate
The number of compressed packets received per second.
rate_rx_compressed
Compressed Packets Transmitted
The count of correctly received compressed packets.
tx_compressed
Compressed Packets Transmitted Rate
The number of correctly received compressed packets per second.
rate_tx_compressed
Conntrack Allowance Available
(AWS Only) Reports the number of available tracked connections that can be established before an instance’s Connections Tracked allowance is exceeded. This metric is supplied by the Elastic Network Adapter (ENA) driver only on AWS.
conntrack_allowance_available
Conntrack Limit Exceeded
conntrack_limit_exceeded
Conntrack Limit Exceeded (%)
per_conntrack_limit_exceeded
Conntrack Limit Exceeded Rate
Conntrack limit exceeded rate.
rate_conntrack_limit_exceeded
Conntrack Usage Rate
(AWS Only) The rate at which conntrack capacity is being used up in connections per second. The Conntrack Usage Rate metric is only available in AWS where the Conntrack Allowance Available (conntrack_allowance_available) metric is present.
conntrack_usage_rate
Drop Rate during Transmission
The number of packets being dropped per second while sending.
rate_tx_drop
20
Drop Rate while Receiving
The number of packets being dropped per second while receiving.
rate_rx_drop
20
Errored Packets Received
The count of packets received that is flagged by the kernel as errored.
rx_errs
Errored Packets Received Rate
The number of packets received per second that is flagged by the kernel as errored.
rate_rx_errs
Errored Packets Transmitted
The total number of transmit problems.
tx_errs
Errored Packets Transmitted Rate
The total number of transmit problems per second.
rate_tx_errs
Interface Drops during Transmission (%)
per_tx_drop
Interface Drops while Receiving (%)
per_rx_drop
Interface Errors during Transmission (%)
per_tx_errs
Interface Errors while Receiving (%)
per_rx_errs
Limit Exceeded Rate (PPS) - AWS Only
The number of packets that exceed the maximum for the instance type that are processed (bidirectionally) by the Aviatrix gateway per second.
rate_pps_limit_exceeded
Linklocal Limit Exceeded
linklocal_limit_exceeded
Linklocal Limit Exceeded (%)
per_linklocal_limit_exceeded
Linklocal Limit Exceeded Rate
rate_linklocal_limit_exceeded
Multicast Packets Received
rx_multicast
Multicast Packets Received Rate
The number of multicast packets per second.
rate_rx_multicast
PPS Limit Exceeded
The count of bidirectional packets that exceed the maximum for the instance type and are handled by the Aviatrix gateway.
pps_limit_exceeded
20
PPS Limit Exceeded Drop (%)
per_pps_limit_exceeded
Packet Drop (%)
Packet Drop (%)
per_pkt_drop
Packet Drop Rate
The rate at which packets are dropped per second.
rate_pkt_drop
20
Packet Failure (%)
Packet Failure (%)
per_pkt_fail
Packet Failure Rate
Packet Failure Rate
rate_pkt_fail
Packets Dropped during Transmission
The count of packets that were dropped during transmission, often due to resource constraints.
tx_drop
20
Packets Dropped while Receiving
The count of received packets that were not processed, typically due to resource limitations or unsupported protocols.
rx_drop
20
Peak Received Rate
Peak Received Rate
rate_peak_received
Peak Total Rate
Peak Total Rate
rate_peak_total
Peak Transmitted Rate
rate_peak_sent
Received Bytes
Received Bytes
rx_bytes
Received Frames Rate
Received Frame Rate
The number of frame alignment errors per second when receiving packets. On AWS, this may occur due to RX buffer overruns on physical interfaces, which can result in packet drops by the NIC.
rate_rx_frame
Received Packets
Received Packets
rx_packets
Received Rate
Received Rate
rate_received
20
Received Rate (PPS)
Packets Received Rate — The total (received) transmission in packet level per second.
pkt_rx_rate
Receiver FIFO Frames
rx_fifo
Receiver FIFO Frames Rate
The number of overflow events per second when receiving packets.
rate_rx_fifo
Received Frames
Received Frames
rx_frame
Total Attempted Rate
rate_pkt_attempted
Total Rate
The total (bidirectional) rate of bits processed per second by the interface on the Aviatrix VM/instance.
rate_total
20
Total Rate (in packets)
The total (bidirectional) transmission in packet level per second. Instance size impacts how many packets per second the gateway can handle.
pkt_rate_total
Transmission FIFO Frames Rate
The number of frame transmission errors per second due to device FIFO underrun/underflow.
rate_tx_fifo
The number of frame transmission errors due to device FIFO underrun/underflow.
tx_fifo
Transmitted Bytes
Transmitted Bytes
tx_bytes
Transmitted Carrier Frames
tx_carrier
Transmitted Carrier Frames Rate
rate_tx_carrier
Transmitted Packets
Transmitted Packets
tx_packets
Transmitted Rate
The rate of bits per second that has been transmitted by the interface on the Aviatrix gateway VM/instance.
rate_sent
20
Transmitted Rate (PPS)
pkt_tx_rate
