Managing Views
On the following pages in CoPilot, you can manage the views you have created:
Cloud Fabric > Topology > Overview (New Topology Experience)
Security > Distributed Cloud Firewall > Monitor
Monitor > Performance
You can only manage views if you have already created and saved views on these pages.
On the Overview tab, expand the Views drop-down and select Manage Views. The Manage Views dialog displays.
From here, you can:
Click the vertical ellipsis
next to the view that you want to use as the default and click Set as Default View. -
Click the delete icon
to remove the view. -
Filter, download, or search the views.
