Gaining Visibility into Your Traffic Flows
For all network traffic moving across your Aviatrix-managed network, Aviatrix gateways capture metadata for all traffic traversing their links. CoPilot uses the information to show you detailed information about your traffic. You can use filters to show flows over custom timeframes. You can use filters to show only traffic that match your specific traffic criteria. You can use over 80 traffic metadata fields to filter traffic.
Show Traffic Flows by Using Filters
You can filter your network traffic to show only the traffic you want by using filters.
To create a traffic flow filter, see:
Traffic Flow Field Reference
You can use over 80 traffic metadata fields when creating custom filters for showing specific traffic flows.
You can filter your traffic in FlowIQ using the following flow fields.
| FlowIQ Field | Description |
Bytes |
Filters traffic by bytes. |
Destination Address |
Filters traffic by destination address. |
Destination Autonomous System |
Filters traffic by properties of the destination autonomous system. |
Destination CSP Tag |
Filters traffic by the destination CSP tag. |
Destination Gateway |
Filters traffic by destination gateway. |
Destination Locality |
Filters traffic by destination locality. |
Destination Port |
Filters traffic by destination port. |
Destination Port Name |
Filters traffic by port name. |
Direction |
Filters traffic by direction. |
Duration |
Filters traffic by how long the flow was active. |
Egress Interface Name |
Filters traffic by egress interface name. |
Egress Physical Interface |
Filters traffic by egress physical interface. |
Engine ID |
Filters traffic by engine ID. |
Engine Type |
Filters traffic by engine type. |
First Switched |
Filters traffic by first switched. |
Flow Locality |
Filters traffic by flow locality. |
Flow Records |
Filters traffic by flow records. |
Flow Sequence Number |
Filters traffic by flow sequence number. |
Flowset ID |
Filters traffic by flowset ID. |
Gateway Host Name |
Filters traffic by gateway host name. |
Geo Autonomous System |
Filters traffic by geo autonomous system. |
Geo Autonomous System Number |
Filters traffic by geo autonomous system number. |
Geo Autonomous System Organization |
Filters traffic by geo autonomous system organization. |
Geo City Name |
Filters traffic by geo city name. |
Geo Continent Code |
Filters traffic by geo continent code. |
Geo Country Code 2 |
Filters traffic by geo country code 2. |
Geo Country Code 3 |
Filters traffic by geo country code 3. |
Geo Country Name |
Filters traffic by geo country name. |
Geo DMA Code |
Filters traffic by geo DMA code. |
Geo Destination Autonomous System |
Filters traffic by geo destination autonomous system. |
Geo Destination Autonomous System Organization |
Filters traffic by geo destination autonomous system organization. |
Geo Destination Autonomous System Organization Number |
Filters traffic by geo destination autonomous system organization number. |
Geo Destination City Name |
Filters traffic by geo destination city name. |
Geo Destination Continent Code |
Filters traffic by geo destination continent code. |
Geo Destination Country Code 2 |
Filters traffic by geo destination country code 2. |
Geo Destination Country Code 3 |
Filters traffic by geo destination country code 3. |
Geo Destination Country Name |
Filters traffic by geo destination country name. |
Geo Destination DMA Code |
Filters traffic by geo destination DMA code. |
Geo Destination IP |
Filters traffic by geo destination IP |
Geo Destination Latitude |
Filters traffic by geo destination latitude. |
Geo Destination Location |
Filters traffic by geo destination location. |
Geo Destination Longitude |
Filters traffic by geo destination longitude. |
Geo Destination Postal Code |
Filters traffic by geo destination postal code. |
Geo Destination Region Name |
Filters traffic by geo destination region name. |
Geo Destination TimeZone |
Filters traffic by geo destination time zone. |
Geo Destination Region Code |
Filters traffic by geo destination region code. |
Geo IP |
Filters traffic by geo IP. |
Geo Latitude |
Filters traffic by geo latitude. |
Geo Location |
Filters traffic by geo location. |
Geo Longitude |
Filters traffic by geo longitude. |
Geo Postal Code |
Filters traffic by geo postal code. |
Geo Region Code |
Filters traffic by geo region code. |
Geo Region Name |
Filters traffic by geo region name. |
Geo Source Autonomous Organization System Number |
Filters traffic by geo source autonomous organization system number. |
Geo Source Autonomous System |
Filters traffic by geo source autonomous system. |
Geo Source Autonomous System Organization |
Filters traffic by geo source autonomous system organization. |
Geo Source City Name |
Filters traffic by geo source city name. |
Geo Source Continent Code |
Filters traffic by geo source continent code. |
Geo Source Country Code 2 |
Filters traffic by geo source country code 2 |
Geo Source Country Code 3 |
Filters traffic by geo source country code 3. |
Geo Source Country Name |
Filters traffic by geo source country name |
Geo Source DMA Code |
Filters traffic by geo source DMA code. |
Geo Source IP |
Filters traffic by geo source IP |
Geo Source Latitude |
Filters traffic by geo source latitude. |
Geo Source Location |
Filters traffic by geo source location. |
Geo Source Longitude |
Filters traffic by geo source longitude. |
Geo Source Postal Code |
Filters traffic by geo source postal code. |
Geo Source Region Code |
Filters traffic by geo source region code. |
Geo Source Region Name |
Filters traffic by geo source region name. |
Geo Source Time Zone |
Filters traffic by geo source time zone. |
Geo Timezone |
Filters traffic by geo time zone. |
Host |
Filters traffic by host. |
ICMP Type |
Filters traffic by ICMP type. |
IP Protocol Version |
Filters traffic by protocol version. |
IP Version |
Filters traffic by IP version. |
Ingress Interface Name |
Filters traffic by ingress interface name. |
Ingress Physical Interface |
Filters traffic by ingress physical interface. |
Input SNMP |
Filters traffic by input SNMP. |
Interface Name |
Filters traffic by interface name. |
JA3 |
Filters traffic by JA3. |
JA3S |
Filters traffic by JA3S type. |
L7 Application Latency |
Filters traffic by L7 application latency. |
L7 Category |
Filters traffic by L7 category. |
L7 FQDN |
Filters traffic by L7 FQDN. |
L7 Protocol |
Filters traffic by L7 protocol. |
L7 Protocol Name |
Filters traffic by L7 protocol name. |
L7 Protocol Risk |
Filters traffic by L7 protocol risk. |
L7 Risk Score |
Filters traffic by L7 risk score. |
Last Switched |
Filters traffic by last switched. |
Mask Length |
Filters traffic by mask length. |
Next Hop |
Filters traffic by next hop. |
Output SNMP |
Filters traffic by output SNMP. |
Packets |
Filters traffic by packets. |
Protocol |
Filters traffic by protocol. |
Protocol Name |
Filters traffic by protocol name. |
Sampling Algorithm |
Filters traffic by sampling algorithm. |
Sampling Interval |
Filters traffic by sampling interval. |
Source Address |
Filters traffic by source address. |
Filters traffic by source autonomous system |
Source CSP Tag |
Filters traffic by source CSP tag. |
Source Gateway |
Filters traffic by source gateway. |
Source Locality |
Filters traffic by source locality. |
Source Mask Length |
Filters traffic by source mask length. |
Source Port |
Filters traffic by source port. |
Source Port Name |
Filters traffic by source port name. |
TCP Flag Tags |
Filters traffic by TCP flag tags. |
TCP Flags |
Filters traffic by TCP flags. |
TCP Flags Label |
Filters traffic by TCP flags label. |
TOS |
Filters traffic by the TOS. |
Throughput |
Filters traffic by the throughput. |
Timestamp |
Filters traffic by timestamp |
Version |
Filters traffic by timestamp. |
World View of Where Traffic is Going To and Coming From
Use the CoPilot > Monitor > FlowIQ > GeoLocation page to see, geographically, where the majority of your traffic is going to and coming from. The world view topology map lets you see where traffic is coming from the most.
If you are not expecting traffic to come into your network from a given country, this may merit further inspection. You can drill into the heat map to analyze the traffic closely by country.
Top Talkers in Your Network and Where They are Communicating
Use the FlowIQ > Flows tab to see the top talkers in your network. The bigger bands in the sankey flow chart represent the top talkers.
You may decide to move top talkers that communicate with each other to be in closer regions to save on cost.
Overview of Your Traffic Statistics
Use the FlowIQ Overview page to get information based on various metrics for all traffic observed in your network over a specified timeframe.
