Supported Edge Hardware for the Aviatrix Edge Platform
Dell Hardware Technical Specifications
Dell PowerEdge R450 Server for Edge Transit or Edge Spoke Gateway
| The Dell PowerEdge R450 for Edge Transit Gateway uses two Ethernet controllers. |
Component  |
Requirement  |
Front Storage  |
Chassis with up to 8x2.5" Drives  |
Backplane  |
SAS/SATA Backplane  |
Trusted Platform Module  |
Trusted Platform Module 2.0 V3  |
Chassis Configuration  |
2.5" Chassis with up to 8 Hard Drives (ChipsetSATA) 1 CPU  |
Processor  |
Intel® Xeon® Gold 5318Y 2.1G, 24C/48T, 11.2GT/s, 36M Cache, Turbo, HT (165W) DDR4-2933  |
Additional Processor  |
No Additional Processor  |
Processor Thermal Configuration  |
Heatsink for 1 CPU configuration (CPU less or equal 165W)  |
Memory Configuration Type  |
Performance Optimized  |
Memory DIMM Type and Speed  |
3200MT/s RDIMMs  |
Memory Capacity  |
32GB RDIMM, 3200MT/s, Dual Rank, 16Gb BASE x8  |
RAID Configuration  |
C20, No RAID with Embedded SATA for SATA HDDs or SATA SSDs (Mixed Drive Types Allowed)  |
Hard Drives  |
480GB SSD SATA Read Intensive 6Gbps 512 2.5in Hot-plug AG Drive, 1 DWPD  |
BIOS and Advanced System Configuration Settings  |
Power Saving Dell Active Power Controller  |
Advanced System Configurations  |
No-OS Partition Removed  |
Fans  |
Standard Fan x5  |
Power Supply  |
Dual, (1+1) Fully Redundant, Hot-Plug Power Supply, 800W MM (100-240Vac)  |
Power Cords  |
(2) NEMA 5-15P to C13 Wall Plug, 125 Volt, 15 AMP, 10 Feet (3m), Power Cord, North America  |
PCIe Riser  |
Riser Config 0, 1xOCP 3.0(x16)+ 1x16LP  |
Motherboard  |
PowerEdge R450 Motherboard with Broadcom 5720 Dual Port 1Gb On-Board LOM  |
OCP 3.0 Network Adapters  |
Intel E810-XXV Dual Port 10/25GbE SFP28, OCP NIC 3.0  |
Additional Network Cards  |
Intel E810-XXV Dual Port 10/25GbE SFP28 Adapter, PCIe Low Profile  |
Bezel  |
No Bezel for x8 Chassis  |
Optics & Cables for Network Cards  |
Select either 25G or 10G. Each server needs four SFPs.
Operating System  |
No Operating System  |
OS Media Kits  |
No Media Required  |
Embedded Systems Management  |
iDRAC9, Enterprise 15G  |
Quick Sync  |
No Quick Sync  |
Password  |
iDRAC,Factory Generated Password  |
IDRAC Service Module  |
iDRAC Service Module (ISM), NOT Installed  |
Group Manager  |
iDRAC Group Manager, Disabled  |
Rack Rails  |
ReadyRails A11 drop-in/stab-in Slide Combo Rails Without Cable Management Arm  |
Internal Optical Drive  |
No Internal Optical Drive  |
System Documentation  |
No Systems Documentation, No OpenManage DVD Kit  |
Shipping  |
PowerEdge R450 Shipping  |
Shipping Material  |
PowerEdge R450 x8 Short Drive Shipping Material  |
Regulatory  |
PowerEdge 1U CCC and BIS Marking, No CE Marking on Chassis  |
Services: Hardware Support  |
Basic Next Business Day 36 Months, 36 Month(s)  |
Services: Extended Service  |
NO WARRANTY UPGRADE SELECTED, 36 Month(s)  |
| Please contact your Aviatrix Sales and Account representative for more information or to place an order. |
