Edge Spoke Gateway Deployment Workflow on Self-Managed VMware ESXi and KVM
This document provides instructions for deploying a primary and secondary highly available (HA) Edge Spoke Gateways on self-managed VMware ESXi or an open-source Kernal-based Virtual Machine (KVM).
Before you deploy an Aviatrix Edge Gateway on VMware ESXi or KVM, ensure the prerequisite requirements are complete, see Prerequisites for Edge Spoke Deployment on VMware ESXi and KVM.
Aviatrix Edge Spoke Gateway Deployment Workflow
To deploy Aviatrix Edge Spoke Gateway, first you need to procure and onboard your edge device on the platform of your choice (see Prerequisites for Edge Spoke Deployment on VMware ESXi and KVM). Next, you deploy the Aviatrix Edge Gateway on the edge device and attach the Edge Gateway to the Aviatrix Transit Gateway for cloud connectivity. Then, configure the Edge Gateway for LAN-side connectivity.
The diagram below provides a high-level view of the four-step process for deploying Aviatrix Edge Spoke Gateway in Aviatrix CoPilot. You have the option to use either VMware ESXi or an open-source Kernel-based Virtual Machine (KVM) to deploy the Edge Spoke Gateway VM and attach the ISO file. The ISO file is the equivalent of the Zero-Touch Provisioning (ZTP) token. ZTP allows to remotely deploy and provision network devices at remote locations.
This workflow provides the steps to create a primary and secondary (HA) Edge Gateway in VMware ESXi and KVM. It also provides the steps to attach the Edge Gateways to a Transit Gateway and connect the Edge Gateways to an external device, such as a LAN BGP router.
You must have port 443 open to the IP address of the Aviatrix Controller. For the required port access for Edge Gateway deployment, refer to Aviatrix Edge Gateway Ports and Protocols. |
Click + Spoke Gateways, then provide the following information.
Select edge_admin.
ZTP File Type
Select the ZTP file type.
For VMware ESXi, select iso.
For KVM, select iso or cloud-init.
Configuring the WAN Interface
| For IP and DNS settings, enter using the applicable format. For example, if the Edge Gateway’s WAN IP is 10.1.1.151, enter 10.1.1.151/24 or what your netmask is. |
| Parameter | Description |
IP Assignment |
The default is Static for static IP assignment. DHCP for dynamic IP address assignment is not supported. |
Interface Labels |
(optional) A name to identify the WAN interface. |
Interface CIDR |
The CIDR for the WAN interface. |
Default Gateway IP |
Public IP |
(optional) The Public IP address of the WAN interface. |
Configuring the LAN Interface
IP Assignment |
VRRP |
If you have Virtual Router Redundancy Protocol (VRRP) configured for the LAN router redundancy, set this switch to On. |
Interface CIDR |
The CIDR for the LAN interface. |
VRRP Gateway IP |
The Virtual IP (VIP) address, when VRRP is enabled. |
(optional) The Default Gateway IP for the LAN interface. |
Interface Labels |
(optional) A name to identify the LAN interface. |
VLAN Interface
| You cannot edit the VLAN ID after the Edge Gateway is created. To edit the VLAN sub-interface attributes, it is highly recommended to delete and recreate the VLAN sub-interface configuration. |
Interface CIDR |
The native VLAN interface IP address. This is the interface where the untagged packets are sent. |
VRRP Gateway IP |
The Virtual IP for the VRRP Gateway, when VRRP is enabled. |
The Default Gateway IP address for the native VLAN interface. |
Interface Labels |
(optional) A name to identify this native VLAN interface. |
VLAN Sub-Interfaces |
VLAN ID |
The VLAN ID. VLAN ID must be a number between 2 and 4092. |
VLAN Interface CIDR |
The VLAN sub-interface IP address. |
VRRP Gateway IP |
The Default Gateway IP address for this VLAN sub-interface. |
Sub-Interface Tag |
(optional) A name to identify this VLAN sub-interface. |
IP Assignment |
Select DHCP or Static, depending on your environment. This setting cannot be changed after the gateway is created. |
Private Network |
If the Management interface connection to the Aviatrix Controller is over a private network, set this switch to On. Leave the setting to Off, if the connection is over the public internet. |
Parameter |
Description |
Egress CIDR (Optional) |
The CIDR range for the egress flow for the Management interface. |
The ISO file expires after 24 hours. You cannot download it again and will have to repeat the above steps. You must mount the ISO file to an Edge VM to complete the Edge Gateway registration within 24 hours. See Deploying the Edge Gateway Virtual Machine Instance. |
To create a secondary (HA) Edge Gateway, follow these steps.
In Aviatrix CoPilot, go to Cloud Fabric > Edge > Gateways tab.
In the Interfaces section, configure the WAN, LAN, and Management interfaces for the secondary (HA) Edge Gateway.
WAN Interface
For IP and DNS settings, enter using the applicable format. For example, if the Edge Gateway’s WAN IP is 10.1.1.151, enter 10.1.1.151/24 or what your netmask is. Parameter Description IP Assignment
LAN Interface
VRRP
VRRP Gateway IP
VLAN Interface
VLAN Sub-Interfaces
VLAN Interface CIDR
VLAN configurations are added to the primary Edge Gateway. On the secondary Edge Gateway, some fields are disabled and non-editable, the field value appears when it is selected. CoPilot creates the ISO file and downloads the file to your downloads folder.
See:
If you have not downloaded the ESXi OVA file, download the file by using the link provided to you by Aviatrix Support. See Download the Aviatrix Secure Edge Image File.
Log in to VMware vSphere Web client to access the ESXi host.
Load the OVA file into the ESXi using vSphere, go to ESXi > Virtual Machines > Create/Register VM.
Select Deploy a virtual machine from an OVF or OVA file and click Next.
Enter a name for the Aviatrix Secure Edge VM and drag the OVA file into the blue pane, then click Next.
In the Select storage page, select the storage device where to create the VM instance (the OVA is installed in this instance) and click Next.
In the Deployment options window, enter the Network mappings for WAN, LAN, and MGMT network interfaces and select the Deployment type. (Refer to the pull-down menu or see Virtual Machine CPU and Memory Configurations.)
Click Next.
In the Ready to complete page, click Finish.
Upload the ISO file downloaded from Aviatrix CoPilot to your VMware datastore.
In vSphere, select the Aviatrix Secure Edge VM you created and click Edit settings.
Select the Virtual Hardware tab.
Next to CD/DVD Drive 1, click the dropdown menu and select Datastore ISO file.
Next to CD/DVD Drive 1, ensure the Connect box is checked and click Save.
Connect at power on is required when you attach the ISO image to the VM for the first time. If the VM is powered on at the time you attach the ISO image, select the ISO file and save the configuration to make the ISO available to ZTP.
Next to the CD/DVD Media, click Browse, locate the datastore and select the ISO file you uploaded.
Click Save. ZTP auto-mounts the ISO file and deploys the Edge Gateway on the VM.
Verify the Edge Gateway is Up (see Verifying the Edge Gateway Creation).
KVM Hypervisor does not support configuration of RX/TX queue size during runtime. RX/TX queue size should be configured during Edge Gateway VM bootup. See Enabling Multiqueue virtio-net on KVM. |
If you have not downloaded the KVM QCOW2 file, download the file by using the link provided to you by Aviatrix Support. See Download the Aviatrix Secure Edge Image File.
Launch Virtual Machine Manager UI to access the KVM host.
Create a new virtual machine from an existing disk image.
From the File menu, select New virtual machine.
Select the option Import existing disk image.
Click Forward.
Provide the path to the KVM QCOW2 file and specify the operating system type and version.
Enter the path or use the Browse button to locate the KVM QCOW2 file you previously downloaded.
For OS type, select Linux.
For Version, select Ubuntu 18.04 LTS.
Click Forward.
Enter the memory and CPU settings for the Edge Gateway VM and click Forward.
Enter a name for the Edge Gateway VM and check the Customize configuration before install checkbox, then click Finish.
Add the LAN and MGMT virtual bridge interfaces.
Click Add Hardware.
In Add New Virtual Hardware, select Network from the left pane and add two additional network interfaces for the LAN and MGMT virtual bridges. The virtual bridge for the WAN interface is automatically added as part of the VM image creation.
For Network source, select the name of the virtual bridge for the LAN interface.
For Device model, select virtio.
Repeat steps a and b and add the virtual bridge for the MGMT interface.
Choose the storage device and attach the ISO file to the VM.
In Add New Virtual Hardware, select Storage from the left pane.
Select the option Select or create custom storage.
Click Manage.
Locate and select the KVM iso file which you previously uploaded.
Click Choose Volume.
Click Finish.
Click Begin Installation to create the Edge Gateway VM on the KVM host.
After the VM is created, ZTP auto-mounts the ISO file and deploys the Edge Gateway on the VM.
Attach an Edge Spoke Gateway to a Transit Gateway
Click Spoke Gateways.
In Edit Edge Gateway, go to Interface Configuration and click WAN.
In Public IP, click Discover.
To create the attachment:
Locate the Edge Spoke Gateway, and click Manage Gateway Attachments icon
on the right side of the row. -
In Manage Gateway Attachments > Transit Gateway tab, click +Attachment and provide the following information.
Transit Gateway
The Transit Gateway in cloud to attach.
Local Edge Gateway Interface
The WAN interface of the local Edge Spoke Gateway to use for the attachment.
Attach Over
The connection between the Edge gateways. It can be over a Private Network or the Public Network.
ActiveMesh
ActiveMesh enables full mesh peering between the local and remote Edge gateways.
For full mesh peering, set ActiveMesh toggle On.
Jumbo Frame improves performance for the connection between the Edge gateways.
Jumbo Frame is applicable when the attachment is over a Private network.
To use Jumbo Frames for the connection , set Jumbo Frame toggle to On.
Number of HPE Tunnels
The number of High Performance Encryption (HPE) tunnels to create for the attachment peering.
Single creates a single tunnel.
Maximum creates the maximum tunnels based on the gateway sizes and the number of interface IPs on the peering gateway.
This option is available only for connection over a Private network.
To attach the Edge Spoke Gateway to another Transit Gateway, click + Attachment again and provide the required information.
You can attach an Edge Spoke Gateway to multiple Transit Gateways. Each attachment can be configured with different parameters, such as connecting interfaces, connection over private or public network, high-performance encryption, and Jumbo Frame.
Click + Attachment and provide the required information.
Field |
Description |
Transit Gateway |
The Transit Gateway in cloud to attach. |
Local Edge Gateway Interface |
The WAN interface of the local Edge Spoke Gateway to use for the attachment. |
Advanced
Field |
Description |
Attach Over |
The connection between the Edge gateways. It can be over a Private Network or the Public Network. |
ActiveMesh |
ActiveMesh enables full mesh peering between the local and remote Edge gateways. For full mesh peering, set ActiveMesh toggle On. |
Jumbo Frame |
Jumbo Frame improves performance for the connection between the Edge gateways. Jumbo Frame is applicable when the attachment is over a Private network. To use Jumbo Frames for the connection , set Jumbo Frame toggle to On. |
Number of HPE Tunnels |
Connect Using
Select BGP.
Type
Select LAN.
This is automatically populated if the Edge Gateway is assigned an ASN already. -
In LAN Configuration, provide the following information.
