About Extending VLAN Segmentation to the Cloud
This document describes the Aviatrix Hybrid Cloud Edge solution to extend virtual LAN (VLAN) network segmentation into cloud.
Aviatrix Multicloud Transit Network architecture
Aviatrix Gateway High-Availability
Virtual LAN networking concepts
Virtual Router Redundancy Protocol (VRRP) concepts
Virtual Local Area Networks (VLANs) enables you to create network segmentation to maintain separation between Local Area Networks. Businesses may deploy network segmentation for additional security or to keep workloads in their network separate.
Aviatrix Edge Spoke Gateway supports multiple VLANs and VRRP architecture. This capability enables you to segment your on-premises network traffic for your LAN network segments. For example, you can segment the workload in the cloud that supports PoS (Point-of-Sale) application to the PoS application at the Edge in that specific LAN segment only.
| VLAN and VRRP support is only available on the Aviatrix Edge Platform and Self-Managed Platform. It is not available on the Equinix Platform. |
VLAN TOPOLOGY
Single VLAN Topology
The topology below illustrates an Edge site with a single VLAN, Virtual Router Redundancy Protocol (VRRP), and the Edge Spoke Gateway deployed as the default LAN router.
In this diagram:
The VRRP and VLAN segment is configured on the primary Edge Spoke Gateway.
The VLAN segment is automatically created symmetrically on the secondary Edge Spoke Gateway.
The VRRP Virtual IP is used by the LAN hosts as the Default Gateway IP.
Multiple VLAN Topology
The topology below illustrates an edge site with multiple VLANs, Virtual Router Redundancy Protocol (VRRP), and Edge Spoke Gateway deployed as the default LAN router.
In this diagram:
The VRRP and VLAN segments are configured on the primary Edge Spoke Gateway.
For multiple Edge Spoke Gateways deployed on an edge site, you configure the VLAN segments on each primary Edge Spok Gateway. The VLAN segments must be configured with the same VLAN ID and CIDR across all the Edge Spoke Gateways on the Edge site. -
The VLAN segments are automatically created symmetrically on the secondary Edge Spoke Gateway(s).
The VRRP Virtual IP is used by the LAN hosts as the Default Gateway IP for the VLAN segments.
The Edge Spoke Gateway provides the trunk interface connectivity to the LAN side switch.
Extending On-Premises VLAN Segmentation into Cloud
To extend on-premises VLAN segmentation into cloud involves these two steps.
Configuring VLAN Interfaces on the Edge Spoke Gateway
You can configure VLAN interfaces on the Edge Spoke Gateway during or after the gateway is created.
To configure VLANs for a new Edge Spoke Gateway, follow the instructions for:
To configure VLANs for an existing Edge Spoke Gateway, perform the steps below.
In Aviatrix CoPilot, go the Cloud Fabric > Hybrid Cloud > Edge Gateways tab.
Click Spoke Gateways.
In the table, locate the Edge Spoke Gateway and click the Edit icon on right side of the row.
In Edit Edge Spoke Gateway, click Next to go to Interface Configuration step.
Click LAN and enable VRRP, if applicable.
Field Description IP Assignment
The default is Static for static IP assignment on this LAN interface.
VRRP
To enable Virtual Router Redundancy Protocol (VRRP) on the Edge Spoke Gateway, set this toggle to On.
Click + VLAN Interface to add one or more VLAN sub-interfaces.
Field Description Interface CIDR
Enter the native VLAN interface IP address.
Default Gateway IP, VRRP Gateway IP
Enter the Default gateway IP address.
If VRRP is enabled, enter the VRRP Gateway IP address.
If VRRP is disabled, enter the Default gateway IP address for the native VLAN interface.
Enter a name to identify this native VLAN interface.
VLAN ID
Enter the VLAN ID.
VLAN Interface CIDR
Enter the VLAN’s interface IP address.
Enter the Default gateway IP address for this VLAN interface.
Sub-Interface Tag
Enter a name to identify this VLAN interface.
If high availability is enabled, the VLAN configurations are added to the secondary Edge Spoke Gateway. If the properties are shared, the fields are disabled on the secondary gateway and non-editable.
If multiple Edge Spoke Gateways are deployed on the edge site, repeat the steps above for each primary Edge Spoke Gateway.
VLAN segments must be configured with the same VLAN ID and CIDR across all the Edge Spoke Gateways for the edge site.
You cannot edit the VLAN ID after it is configured. To edit the VLAN sub-interface attributes, it is highly recommended to delete and recreate the VLAN sub-interface configuration.
Associating VLANs to Aviatrix Network Domains
Aviatrix Edge Spoke Gateway enables you to segment your on-premises network traffic through network domains and connection policies. The Edge Spoke Gateway routes on-premises and inter-VLAN traffic flow based on the network domain connection policies.
To segment the on-premises network traffic, you associate the VLAN segment and its workload in the CSP to the same network domain.
For example, the diagram below illustrates on-premises network traffic flow between the yellow and orange domains that are segmented.
VLAN 100 is associated to the same network domain as its workload in the CSP.
VLAN 200 is associated to the same network domain as its workload in the CSP.
To create network segmentation between VLANs and Spoke VPCs Or VNets, you associate the VLANs and Spoke VPCs or VNets to network domains. When network segmentation is configured with multiple Edge Spoke Gateways using VLAN, the same VLAN ID is associated to the network segment across all the gateways for the edge site.
If VLANs are created or added after the network domain association is created, the association must be removed and reconfigured.
In Aviatrix CoPilot, go to Networking > Network Segmentation > Network Domains tab.
To add a new network domain, click + Network Domain.
Field Description Name
Enter a unique name for this network domain.
A network-domain name can only have letters, digits, a hyphen (-), and an underscore (_). The name must start with a letter and must have 2-27 characters. For example, Dev_Domain.
After you create and save a network domain, you cannot change its name. Association
From the dropdown list, select the Spoke VPC/VNet and the VLAN that are in this network domain.
Connect to Network Domain
To connect this network domain to another network domain, from the dropdown list, select the other network domain.
This enables traffic flow between both network domains.
Disabling LAN and VLAN CIDR Propagation to the Transit Gateway
The Aviatrix Edge Spoke Gateway exchanges routes with the Transit Gateways. The Edge Spoke Gateway advertises the CIDRs associated with the LAN and VLAN interfaces to the Transit Gateway, by default. If you do not need LAN CIDR propagation, you can disable this feature.
| If there are workloads on the LAN or the VLAN CIDR, then disabling LAN and VLAN interface CIDR propagation may cause network traffic to be dropped, since Transit Gateway will not have learned the LAN or VLAN CIDRs. |
Select the Edge Spoke Gateway for which to disable LAN CIDR propagation.
In the Edge Spoke Gateway’s Settings tab, expand the Routing section.
Set LAN/VLAN Interface CIDR Propagation toggle to Off.
