Prerequisites for Aviatrix Secure Edge Deployment on Equinix Network Edge
The following are the prerequisites to deploy an Aviatrix Edge Gateway on Equinix Network Edge.
1. Obtain an Equinix Fabric Account
If you do not already have an Equinix Fabric account, contact your Equinix representative or visit their website to create an account.
2. Set Up the Equinix Platform Account
To enable access to provision the edge virtual device on the Equinix platform, you will need to first set up an Equinix platform account in CoPilot.
3. Provide Network Access
Refer to Aviatrix Edge Gateway Ports and Protocols for the network access requirements for the Edge Gateway to communicate with the Aviatrix Controller, Aviatrix CoPilot, and the Aviatrix Transit Gateway.
4. Obtain Edge Gateway Interface Configurations
Setting | Description |
WAN Interface IP/Mask |
The WAN IP address. |
WAN Default Gateway |
LAN Interface IP/Mask |
The LAN IP address. |
LAN Default Gateway |
Management Interface IP/Mask |
The Management IP address. Not required for DHCP. |
Management Default Gateway |
The Default Gateway IP address for the Management interface. Not required for DHCP. |
Management Egress IP |
The Management Egress IP address to be allowed in the Controller Security Group. |
Primary DNS Server |
The Primary DNS server IP address for the Management interface. Not required for DHCP. |
Secondary DNS Server |
(Optional) The Secondary DNS server IP address for the Management interface. Not required for DHCP. |
