Prerequisites for Edge Transit Gateway Deployment on Equinix Network Edge
The following are the prerequisites to deploy an Aviatrix Edge Transit Gateway on Equinix Network Edge.
1. Obtain an Equinix Fabric Account
If you do not already have an Equinix Fabric account, contact your Equinix representative or visit their website to create an account.
2. Set Up the Equinix Platform Account
To enable access to provision the edge virtual device on the Equinix platform, you will need to first set up an Equinix platform account in CoPilot.
3. Provide Network Access
Aviatrix Edge Gateway requires outbound access to communicate with the Aviatrix Controller, Aviatrix CoPilot, and other Aviatrix Gateways. You must allow access on the specified ports on your firewall.
4. Obtain Edge Gateway Interface Configurations
The Edge Transit Gateway on the Equinix Network Edge supports one Management and up to 9 WAN interfaces.
For each WAN interface that you want to configure, you will need to provide the following information during Edge Gateway creation for your primary and secondary HA Edge Gateways.
WAN Interface
Interface Primary CIDR
If you need to create a BGP underlay connection to cloud service provider (CSP) with a link-local IP address, you must provide the Link-local Underlay CIDR for the WAN interface.
Interface Secondary CIDRs
Secondary CIDR cannot be link-local CIDR.
If you need to setup BGP underlay connection to the Cloud Service Provider (CSP), you will need to provide the following information.
BGP Configuration
For the Management interface, you will need the Egress IP.
Management Interface
Egress CIDR (Primary)
In Equinix, the public IP is auto assigned. Configure the Equinix provided public IP as the CIDR. The CIDR is then added to the Controller security group to allow incoming traffic from the Edge Gateway.
Egress CIDR (Secondary)
The Egress public IP for the secondary Edge Gateway’s Management interface when High Availability is configured.
