Prerequisites for Edge Spoke Gateway Deployment on Equinix Network Edge
The following are the prerequisites to deploy an Aviatrix Edge Gateway on Equinix Network Edge.
1. Obtain an Equinix Fabric Account
If you do not already have an Equinix Fabric account, contact your Equinix representative or visit their website to create an account.
2. Set Up the Equinix Platform Account
To enable access to provision the edge virtual device on the Equinix platform, you will need to first set up an Equinix platform account in CoPilot.
3. Provide Network Access
Aviatrix Edge Gateway requires outbound access to communicate with the Aviatrix Controller, Aviatrix CoPilot, and other Aviatrix Gateways. You must allow access on the specified ports on your firewall.
4. Obtain Edge Gateway Interface IP Configurations
Setting Description
WAN Interface IP/Mask
The WAN IP address.
WAN Interface Secondary IP/Mask
WAN Secondary Interface CIDR.
Required for BGP connection when the WAN IP is a link-local address (address is in the range 169.254.0.0 - 169.254.255.255).
WAN Default Gateway
LAN Interface IP/Mask
The LAN IP address.
LAN Default Gateway
Management Interface IP/Mask
The Management IP address.
Not required for DHCP.
Management Default Gateway
The Default Gateway IP address for the Management interface.
Management Egress IP
The Management Egress IP address to be allowed in the Controller Security Group.
Primary DNS Server
The Primary DNS server IP address for the Management interface.
Secondary DNS Server
(Optional) The Secondary DNS server IP address for the Management interface.
