Edge Spoke Gateway Deployment Workflow for On-Premises
This document provides instructions for deploying a primary and secondary highly available (HA) Edge Spoke Gateways on Aviatrix Edge Platform.
  • Single VLAN connected to the Edge Gateway via a single vNIC.
  • Multiple VLANs connected to the Edge Gateway via a single vNIC (Trunk Port) and sub-interfaces for each VLAN.
  • VRRP on Edge Gateway.
  • LAN-side BGP.
  • Connectivity to single or multiple Transit Gateways from Edge Gateway.
650
Before you can deploy an Edge Spoke Gateway on the Aviatrix Edge Platform:
  1. You must perform the prerequisite steps to procure and onboard your edge device. See Prerequisites for Edge Spoke Gateway Deployment for On-Premises.
  2. You should be familiar with the Edge Spoke Gateway interfaces. See Edge Spoke Gateway Interfaces.
Edge Spoke Gateway Deployment Workflow in Aviatrix Edge Platform
To deploy an Edge Spoke Gateway, first you need to procure and onboard your edge devices on the platform of your choice (see Prerequisites for Edge Spoke Gateway Deployment for On-Premises).
Next, you deploy the primary and secondary highly available (HA) Edge Spoke Gateways on the edge devices. For cloud connectivity, attach the primary Edge Spoke Gateway to the Transit Gateway. For LAN-side connectivity, attach the primary Edge Spoke Gateway and the LAN-side router.
The diagram below provides a high-level view of the process for deploying Edge Spoke Gateway using Aviatrix CoPilot.
edge aviatrix workflow
The workflow below guides you through these steps.
Creating the Primary and Secondary Edge Spoke Gateway (Aviatrix Edge Platform)
To create a primary and secondary (HA) Edge Spoke Gateway, follow these steps:
Step 1: Gateway Configuration
  1. In Aviatrix CoPilot, go to Cloud Fabric > Hybrid Cloud > Edge Gateways > Spoke Gateways tab.
  2. Click + Spoke Gateway, then provide the following information.
    You can create and edit platform accounts in CoPilot by going to Cloud Fabric > Hybrid Cloud > Platforms tab. See Set Up the Aviatrix Edge Platform Account.
    Identifies the edge location.
    The high availability mode.
    • Off creates only the primary Edge Gateway with one active peering.
    • On (Active Standby Mode) enables Edge Gateway connection with one active peering and one standby peering. Only the active peering forwards network traffic. The network switches to the standby peering when the primary peering goes down.
    • On (Active Active Mode) enables Edge Gateway connections with all active peerings to perform load sharing and forward network traffic.
    Preemptive
    Determines the network’s behavior when the primary gateway goes down.
    Preemptive is applicable only when High Availability is set to On with Active Standby Mode. The Preemptive is set on the primary gateway.
    • On enables the network to automatically switch back to the primary gateway when the primary gateway connection is back up.
    • Off enables the network to continue to use the standby gateway even after the primary gateway is back up, until you initiate a manual switchover.
    Primary Device
    Secondary Device
    The primary and secondary devices must have the same hardware configuration.
    Gateway Resource Size
    The gateway size.
    • Small - 2 vCPU - 4GB
    • Medium - 4 vCPU - 8GB
    • Large - 8 vCPU - 16GB
    • X-Large - 16 vCPU - 32GB
  3. Click Next to configure the gateway interfaces.
By default, an Edge Spoke Gateway has three interfaces: one WAN interface on eth0, one LAN interface on eth1, and one Management interface on eth2. You will need these configuration information to configure the interfaces.
In the Interface Configuration section, configure the WAN, LAN, and Management interfaces. If High Availability mode is selected, then configure both the primary and secondary Edge Gateways.
Configuring the WAN Interface
To configure the WAN interface:
  1. In Interface Configuration, click WAN, then provide the following information.
    Interface
    IP Assignment
Configuring the LAN Interface
To configure the LAN interface:
  1. Click LAN, then provide the following information.
    Interface
    IP Assignment
    VRRP
    VRRP can be configured only if HA Edge Gateway is configured.
    VRRP Gateway IP
  2. If your LAN is segmented into virtual LANs (VLANs), click + VLAN Interface to add one or more VLAN sub-interfaces, then provide the following information for each VLAN sub-interface.
    You cannot edit the VLAN ID after the Edge Gateway is created. To edit the VLAN sub-interface attributes, it is highly recommended to delete and recreate the VLAN sub-interface configuration.
    VLAN ID
    The VLAN ID of the VLAN segment.
    VLAN Interface CIDR
    The VLAN IP address of the VLAN segment.
    The Default Gateway IP address of the VLAN segment.
    Sub-Interface Tag
    Name to identify the VLAN segment.
    When a secondary HA Edge Gateway is configured, the VLAN configurations that are shared between the primary and secondary gateway and are non-editable on the secondary gateway.
To configure the Management interface, click MGMT, then provide the following information.
Interface
IP Assignment
Private Network
Leave this setting to Off.
Egress CIDR (Primary)
Egress CIDR (Secondary)
Step 3: Verify the Edge Gateway Creation
Attaching Edge Spoke Gateway to Transit Gateway
  1. Ensure Local ASN Number is configured on Edge and Transit Gateway.
  2. If the Edge to Transit Gateway attachment is over public network, you need to update the WAN Public IP on the Edge Gateway.
    1. Go to Cloud Fabric > Hybrid Cloud > Edge Gateways tab.
    2. Click Spoke Gateways.
    3. Locate the Edge Gateway, and click its Edit icon on the right.
    4. In Edit Edge Gateway, go to Interface Configuration and click WAN.
    5. In Public IP, click Discover.
      edge discover public ip
    6. Verify the WAN Public IP and click Save.
  • To create a High Performance Encryption mode attachment, make sure the Transit Gateway is created with High Performance Encryption enabled.
  • If you want Jumbo Frame enabled on the Edge Gateway, make sure to enable Jumbo Frame on the Edge Gateway before you attach it to the Transit Gateway.
To create the attachment:
  1. In Aviatrix CoPilot, go to Cloud Fabric > Hybrid Cloud > Edge Gateways tab.
  3. Locate the Edge Gateway, and click Manage Gateway Attachments icon on the right side of the row.
  4. In Manage Gateway Attachments > Transit Gateway tab, click +Attachment and provide the following information.
    Transit Gateway
    Local Edge Gateway Interface
    Attach Over
    Number of Tunnels
    • Max Tunnels creates the maximum tunnels based on the gateway sizes and the number of interface IPs on the peering gateway.
    • Custom allows you to specify the number of tunnels to create.
  5. To attach the Edge Gateway to another Transit Gateway, click + Attachment again and provide the required information.
  6. Click Save.
  1. In CoPilot, navigate to Networking > Connectivity > External Connections (S2C) tab.
  2. From + External Connection To dropdown menu, select External Device, then provide the following information.
    Connect Using
    Select BGP.
    Type
    Select LAN.
  3. In LAN Configuration, provide the following information.
  4. Click Save.
