Edge Spoke Gateway Deployment Workflow on Megaport Virtual Edge
Aviatrix Edge on Megaport Virtual Edge is available as a Preview Feature in CoPilot version 4.11 with Controller version 7.1.3958.
This document provides instructions for deploying a primary and secondary highly available (HA) Edge Spoke Gateways on Megaport Virtual Edge.
The design below shows a high-level hybrid cloud solution with Aviatrix Edge leveraging Megaport fabric.
edge megaport topology
Before you deploy an Aviatrix Edge Gateway on the Megaport Virtual Edge platform, you must perform the prerequisite steps to set up a Megaport Portal account and a Network Service Provider Platform account.
For instructions on how to create these accounts, see Prerequisites for Edge Spoke Gateway Deployment on Megaport Virtual Edge.
Edge Spoke Gateway Deployment Workflow in Megaport
To deploy Aviatrix Edge Spoke Gateway, first you need to procure and onboard your edge device on the platform of your choice (see Prerequisites for Edge Spoke Gateway Deployment on Megaport Virtual Edge). Next, you deploy the Aviatrix Edge Gateway on the edge device and attach the Edge Gateway to the Aviatrix Transit Gateway for cloud connectivity. Then, configure the Edge Gateway for LAN-side connectivity.
This workflow provides the steps to create a primary and secondary (HA) Edge Gateway in Megaport Virtual Edge. It also provides the steps to attach the Edge Gateways to a Transit Gateway and connect the Edge Gateways to an external device, such as a LAN BGP router.
Creating the ZTP Cloud-Init and Deploying Primary Edge Gateway (Megaport)
The Edge Gateway cloud-init ZTP file is used to provision the Aviatrix Edge Gateway virtual machine and create the Edge Gateway in Megaport Virtual Edge (MVE).
To create the primary Edge Gateway, follow these steps.
Step 1: Gateway Configuration
  1. In CoPilot, go to Cloud Fabric > Hybrid Cloud > Edge Gateways tab.
  2. Click Spoke Gateways, then click +Spoke Gateway and provide the following information.
    Identifies the edge location.
    See Edge site.
    ZTP File Type
    This is set to cloud-init.
    See Edge Spoke Gateway High Availability.
  3. Click Next to configure the edge gateway interfaces.
Step 2: Interface Configurations
By default, an Edge Spoke Gateway has three interfaces: one WAN interface, one LAN interface, and one Management interface. You can configure multiple WAN interfaces on the Edge Gateway, as needed. You will need these configuration information to configure the interfaces.
Configuring the WAN Interface
You can configure multiple WAN interfaces on the Edge Gateway. Megaport MVE supports a maximum of 5 interfaces. Aviatrix Edge Gateway requires at least 3 interfaces (WAN, LAN, and MGMT), additional two interfaces can be WAN interfaces.
  1. Click + WAN Interface, then provide the following information.
    Interface
    Adding multiple WAN interfaces is applicable when the Edge Gateway is set up for BGP underlay to cloud service provider (CSP).
    Edge Gateway WAN support for BGP underlay to CSP is supported for AWS, Azure, and GCP.
    Interface Primary CIDR
  2. If BGP is turned On, provide the following information:
    Password (optional)
    The MD5 authentication key.
  3. If BGP is turned On, in Gateway Configuration, enter the Local AS Number of the Edge Gateway.
  4. To add another WAN interface, click + WAN again and provide the required information.
Configuring the LAN Interface
To configure the Edge Gateway LAN interface, click + LAN Interface, then provide the following information.
Interface
  1. Click MGMT, then click + MGMT interface.
  2. Leave the default settings and click Save.
    Leave the Private Network setting to Off. In the Megaport fabric, the MGMT interface of the Edge Gateway is assigned the Public IP address that is allocated by Megaport.
  3. To create the ZTP cloud-init image file, click Done.
    Next, log in to Megaport and deploy the Edge Gateway VM instance and attach the cloud-init image file to complete the Edge Gateway creation and authentication with the Aviatrix Controller.
    The cloud-init image file expires after 24 hours. You cannot download it again and will have to repeat the above steps to recreate the file. You must launch an Edge MVE on the Megaport platform and deploy the Edge Gateway within the 24 hours.
Step 3: Deploy the Edge Gateway in Megaport Virtual Edge
Creating the ZTP Cloud-Init and Deploying the Secondary Edge Gateway (Megaport)
  • Before you can create the secondary highly available (HA) Edge Gateway, the primary Edge Gateway must be deployed and its status must be Up.
  • When creating the HA Edge Gateway, the primary Edge Gateway cannot have BGP underlay or BGP over LAN external connections. This does not apply when multiple Edge Gateways are created in the same site without HA configuration.
  • Edge Gateway high availability on the Megaport Platform is supported on the latest Aviatrix Controller release version.
To create a highly available (HA) Edge Gateway, follow these steps.
  1. Go to Cloud Fabric > Hybrid Cloud > Edge Gateways tab.
  3. In the table, locate the primary Edge Gateway for which you want to create the HA gateway and click its Edit icon.
  4. In Edit Edge Gateway, from the High Availability dropdown menu, select Active-Active or Active-Standby mode.
  5. Click Next to configure the edge gateway interfaces.
In Interface Configuration section, configure the WAN, LAN, and Management interfaces of the secondary (HA) Edge Gateway.
You can configure multiple WAN interfaces on the Edge Gateway. Megaport MVE supports a maximum of 5 interfaces. Aviatrix Edge Gateway requires at least 3 interfaces (WAN, MGMT and LAN), additional two interfaces can be WAN interfaces.
    Parameter Description
    Edge Gateway Interface
    This is set to eth0.
    Adding multiple WAN interfaces is applicable when Edge Gateway is used for BGP underlay to CSP. Add an interface per CSP underlay (such as Direct Connect or Express Route).
    WAN support for BGP underlay to CSP is supported for AWS and Azure.
    The ASN of the Edge Gateway.
    Password (optional)
  1. Click LAN, then provide the following information.
    This is set to eth1.
  1. Click + MGMT interface. Leave the default settings and click Save.
    Leave the Private Network setting to Off. In the Megaport Fabric, the MGMT interface of the Edge Gateway is assigned the Public IP address that is allocated by Megaport.
    edge equinix ha mgmt interface
  2. To create the ZTP cloud-init image file, click Save and Download Configuration.
Attaching Edge Spoke Gateway to Transit Gateway
  1. Ensure Local ASN Number is configured on Edge and Transit Gateway.
  2. If the Edge to Transit Gateway attachment is over public network, you need to update the WAN Public IP on the Edge Gateway.
    2. Click Spoke Gateways.
    3. Locate the Edge Gateway, and click its Edit icon on the right.
    4. In Edit Edge Gateway, go to Interface Configuration and click WAN.
    5. In Public IP, click Discover.
      edge discover public ip
    6. Verify the WAN Public IP and click Save.
  • To create a High Performance Encryption mode attachment, make sure the Transit Gateway is created with High Performance Encryption enabled.
  • If you want Jumbo Frame enabled on the Edge Gateway, make sure to enable Jumbo Frame on the Edge Gateway before you attach it to the Transit Gateway.
To create the attachment:
  1. In Aviatrix CoPilot, go to Cloud Fabric > Hybrid Cloud > Edge Gateways tab.
  3. Locate the Edge Gateway, and click Manage Gateway Attachments icon on the right side of the row.
  4. In Manage Gateway Attachments > Transit Gateway tab, click +Attachment and provide the following information.
    Transit Gateway
    Local Edge Gateway Interface
    Attach Over
    Number of Tunnels
    • Max Tunnels creates the maximum tunnels based on the gateway sizes and the number of interface IPs on the peering gateway.
    • Custom allows you to specify the number of tunnels to create.
  5. To attach the Edge Gateway to another Transit Gateway, click + Attachment again and provide the required information.
  6. Click Save.
  1. In CoPilot, navigate to Networking > Connectivity > External Connections (S2C) tab.
  2. From + External Connection To dropdown menu, select External Device, then provide the following information.
    Connect Using
    Select BGP.
    Type
    Select LAN.
  3. In LAN Configuration, provide the following information.
  4. Click Save.
