Prerequisites for Edge Transit Gateway Deployment for On-Premises
The following are the prerequisites to deploy an Aviatrix Edge Transit Gateway for on-premises on the Aviatrix Edge platform.
1. Procure the Edge Hardware
If you do not already have your edge device, you need to evaluate the hardware that you require for your edge computing and procure the hardware. Contact your Aviatrix account manager for the hardware you may require.
For a list of Aviatrix supported hardware appliances, see Supported Edge Hardware for the Aviatrix Edge Platform.
2. Obtain the Hardware Serial Number
To onboard and register the edge device with the Aviatrix Edge platform, you will be required to provide the device serial number. Obtain the serial numbers for your edge device.
3. Set Up the Aviatrix Edge Platform Account
To onboard and register the edge device requires an Aviatrix Edge Platform Account.
To set up the Edge platform account, see Setting up Accounts for Edge Platforms.
4. Onboard the Edge Hardware
You must onboard and register the edge device before you can deploy an Edge Gateway on the edge device.
To onboard edge hardware, see Onboarding Edge Device for the Aviatrix Edge Platform.
5. Obtain Edge Gateway Interface Configurations
The Edge Transit Gateway on the Aviatrix Edge Platform supports one Management and up to 4 WAN interfaces.
For each WAN interface that you want to configure, you will need to provide the following information during Edge Gateway creation for your primary and secondary HA Edge Gateways.
WAN Interface | Description | ||
Interface Primary CIDR |
The CIDR for the WAN interface. Interface CIDR must be in the format interface_ip/netmask (for example, 192.18.20.1/24).
If you need to create a BGP underlay connection to cloud service provider (CSP) with a link-local IP address, you must provide the Link-local Underlay CIDR for the WAN interface. |
Interface Secondary CIDRs |
The secondary CIDRs for the WAN interface. Interface CIDR must be in the format interface_ip/netmask (for example, 192.18.20.1/24). The secondary CIDRs are used for High Performance Encryption (HPE) attachment peering connections over a private network between the Edge Transit Gateway to another Edge Transit Gateway or Edge Spoke Gateway. The secondary IP addresses (based on the secondary CIDRs) are automatically assigned to create the peering connections. You can define /32 CIDR for specific secondary IP address.
Default Gateway IP |
Public IP |
If the Edge Gateway deployed on a physical appliance is being used in environments where there are connections to Cloud Service Providers (CSPs) available, then BGP configurations can be set up on Edge Gateway to peer with cloud routers such as VGW, VNG and Google Cloud router.
For BGP underlay connections to CSP, you will need to provide the following information.
BGP Configuration | Description |
Remote ASN |
The AS Number of the remote BGP peer. |
Remote LAN IP |
The IP address of the remote BGP peer. |
For the Management interface, you will need the Egress IP.
MGMT Interface |
Description |
Egress CIDR (Primary) |
The Egress CIDR is the public IP address which the Management interface uses. If the public IP is used from Edge Gateway Management interface to establish connectivity to Aviatrix Controller, then configure the public IP as the CIDR. The CIDR is then added to the Controller security group to allow incoming traffic from the Edge Gateway. |
Egress CIDR (Secondary) |
The Egress public IP for the secondary Edge Gateway’s Management interface when High Availability is configured. |
6. Provide Network Access
Aviatrix Edge Gateway requires outbound access to communicate with the Aviatrix Controller, Aviatrix CoPilot, and other Aviatrix Gateways. You must allow access on the specified ports on your firewall.
