Managing Edge Transit Gateway Attachments
An Edge Transit Gateway can be attached to multiple gateways for multi-network, multicloud, and LAN connectivity.
For encrypted connectivity across environments like Equinix, Megaport, and Datacenter fabric, you attach an Edge Transit Gateway to another Edge Transit Gateway.
For encrypted connectivity to cloud, you attach an Edge Transit Gateway to a Transit Gateway.
For encrypted connectivity to remote Datacenter or on-premises, you attach An Edge Transit Gateway to an Edge Spoke Gateway.
Creating an Edge Transit Gateway to Edge Transit Gateway Attachment
If you want to use Jumbo Frames for the attachment peering connection between the Edge Gateways, make sure to enable Jumbo Frames on the Edge Gateways before you create the attachment. |
To attach an Edge Transit Gateway to another Edge Transit Gateway:
Locate the Edge Transit Gateway to which you want to attach another gateway, then click the Manage Gateway Attachments icon on the right side of the row.
Transit Gateway
From the dropdown menu, select the remote Edge Transit Gateway you want to attach to the local Edge Transit Gateway.
Local Edge Gateway Interface
Remote Edge Gateway Interface
From the dropdown menu, select the WAN interface of the remote Edge Transit Gateway you want to attach.
Attach Over
On the Aviatrix Edge Platform (AEP), Edge Transit Gateway to Edge Transit Gateway peering for high performance encryption is supported over private and public networks.
On the Equinix and Megaport platforms, Edge Transit to Edge Transit peering for high performance encryption is supported over private network only .
High Performance Encryption
Number of Tunnels
Custom allows you to specify the number of tunnels to create. Supported range is 2 and 20 tunnels.
Excluded Network CIDRs
To attach the Edge Transit Gateway to another Edge Transit Gateway, click + Attachment again and provide the required information.
You can attach an Edge Transit Gateway to multiple Edge Transit Gateways. Each attachment can be configured with different parameters, such as connecting WAN interfaces, connection over private or public networks, and enabling high-performance encryption.
Transit Gateway
Attach Over
Number of Tunnels
Custom allows you to specify the number of tunnels to create. Supported range is 2 and 9 tunnels.
Spoke Gateway
Attach Over
On the Aviatrix Edge Platform (AEP), Edge Transit Gateway to Edge Spoke Gateway peering for high performance encryption over private and public networks is supported .
On the Equinix and Megaport platforms, Edge Transit Gateway to Edge Spoke Gateway peering for high performance encryption is supported over private networks only .
Number of Tunnels
