Resources
Terraform Support
Request Demo
CoPilot
Latest Versions
  • Controller
  • CoPilot
      • What’s New
      • Aviatrix CoPilot Overview
        • What’s New in CoPilot?
        • Aviatrix Feature Modes
        • Aviatrix CoPilot Features
        • Aviatrix CoPilot Platform
      • Getting Started
          • CoPilot Platform Requirements
          • CoPilot Deployment Methods
          • CoPilot Simple Deployment
          • CoPilot Fault Tolerant Deployment
          • Deploy CoPilot from your Controller UI (AWS Only)
          • Deploy CoPilot using Terraform
        • Post CoPilot Deployment Tasks
          • Initial Setup of CoPilot
          • CoPilot Settings to be Enabled in Controller
          • (Optional) Enable CoPilot Add-on Features
          • Set Up SAML Login for CoPilot
        • Logging in to CoPilot
        • Using Aviatrix CoPilot
          • CoPilot Navigation Menu
        • Deleting a CoPilot instance
      • Accounts and Users
        • Users and Permissions
        • Creating a Cloud Account
        • Auditing a Cloud Account
        • Deleting a Cloud Account
        • AWS IAM Overview
      • Building Your Network
        • Overview of Transit Network Features
          • About Aviatrix ActiveMesh
            • ActiveMesh Design Notes
          • About Aviatrix High-Performance Encryption
          • About Aviatrix Gateway High Availability
          • About Aviatrix Gateway Scaling
          • Deploying Azure Gateways and Firewalls using PowerShell
          • About Transit Network Segmentation Overview
        • Building a Single-Region Transit Network
        • Building a Multi-Region Transit Network
          • Building Aviatrix Transit Gateway Peering
          • Building Multicloud Transit Gateway Peering over Private Network
          • Building Multicloud Transit Gateway Peering over Public Network
        • Connecting the Transit Network to On-Premise
          • Overview of Connectivity options
          • Multicloud Transit Integration with External Devices
            • Multicloud Transit to External Devices Workflow
            • About External Device Connection Settings
            • Viewing External Connection Details
            • External Device Connection for AWS VGW
            • External Device Connection for Azure VNG
            • Static Policy-Based External Connection
            • Static Route-Based External Connection (ActiveMesh)
            • Static Route-Based External Connection (Mapped)
            • Static Route-Based External Connection (Non-ActiveMesh)
          • Multicloud Transit Integration with AWS VGW Workflow
          • Multicloud Transit Integration with Azure VNG Workflow
          • Multicloud Transit GRE Tunneling in AWS Workflow
          • MultiCloud Transit BGP over LAN in AWS Workflow
          • Multicloud Transit BGP over LAN in Azure Workflow
          • Multicloud Transit BGP over LAN in GCP Workflow
          • Transit Gateway to External Device FAQ
        • Extending Transit Network to Network Edge with Aviatrix Secure Edge
          • Overview of Aviatrix Secure Edge
          • Aviatrix Secure Edge Design Patterns
          • Planning your Aviatrix Secure Edge Deployment
            • Onboarding Edge Hardware
            • Planning Aviatrix Secure Edge Deployment for On-Premise
            • Planning Aviatrix Secure Edge Deployment for Equinix Network Edge
          • Deploying Aviatrix Secure Edge
            • About Aviatrix Edge Gateway Interfaces and Ports and Protocols
            • Understanding Aviatrix Secure Edge Routing
            • About Edge Gateway Settings
            • Deploying Aviatrix Secure Edge on Equinix Network Edge
            • Deploying Aviatrix Secure Edge in On-Premises
          • Enabling Edge Gateway High Availability
          • Customized SNAT and DNAT on Edge Use Case
          • Implementing Network Segmentation with Aviatrix Edge
          • Enabling Local Internet Breakout at Network Edge
          • Extending Distributed Cloud Firewall to your Network Edge
          • Configuring Transitive Routing with Edge Gateway
          • Configuring Transit Peering Over Public Network with Edge Gateway
        • Connecting Remote Sites to Cloud
          • Site2Cloud Configuration Workflow
            • Connecting On-Prem with Overlapping CIDRs Using Customized SNAT and DNAT on Spoke Gateway
        • Overview of UserVPN
          • Aviatrix UserVPN Feature Description
          • Aviatrix UserVPN FAQ
          • Aviatrix User VPN Client
          • UserVPN Gateway Guide
            • Creating a User VPN Default Gateway
            • Creating a Geo VPN Gateway
            • About VPN Gateway Settings
            • Editing VPN Gateways
            • Deleting a VPN Gateway
          • Aviatrix VPN Client (Release Notes)
          • UserVPN SAML Authentication
            • UserVPN with SAML Authentication for Okta IdP
            • UserVPN with SAML Authentication for OneLogin IdP
            • UserVPN with SAML Authentication for Azure AD IdP
            • UserVPN with SAML Authentication for LDAP IdP
            • UserVPN Okta Authentication
            • UserVPN DUO Authentication
        • Enabling Gateway Settings
          • Enabling Public Subnet Filtering Gateway Settings
          • Enabling Gateway NAT Settings
          • Enabling Gateway BGP Connection Settings
          • Enabling Cloud Service Provider Settings
          • Enabling Gateway Routing Features
          • Using VPC/VNet DNS Server
          • Enabling BGP Route Approval
          • About Gateway States
          • TGW Design Patterns
          • Creating TGW Connects
        • AWS Limitations and Solutions
        • Extending Your VMware Workloads to Public Cloud
        • Migrating from Classic Aviatrix Encrypted Transit Network to Aviatrix ActiveMesh Transit Network
        • Visualizing Your Network
        • Understanding SmartGroups
          • Creating a SmartGroup
          • Deleting a SmartGroup
          • Modifying a SmartGroup
          • SmartGroups Readme
        • SmartGroups Reference
          • Working with SmartGroups
      • Distributed Cloud Firewall and Security
        • Distributed Cloud Firewall: inspection and enforcement throughout the cloud network
        • About Secured Networking and Security Services
        • Implementing Network Segmentation in an Aviatrix-Managed Network
        • Implementing Distributed Cloud Firewall in an Aviatrix-Managed Network
            • Enabling the Feature after Changing Licenses
            • Creating Policies
        • Planning Your Ingress Traffic Deployment
        • Implementing Egress in an Aviatrix-Managed Network
          • Using Distributed Cloud Firewall to Configure Egress
          • Egress FQDN Workflow (Legacy)
          • Enabling Local Egress
          • Egress Traffic Overview
          • Egress Monitoring
        • FireNet Deployment Workflow
          • Add FireNet to a Transit Gateway
          • Editing a Transit FireNet
          • Removing Transit FireNet
          • Transit FireNet Settings
          • FireNet Design Patterns
            • Hybrid to On-Prem
            • Hybrid with High Performance Encryption Mode
            • FireNet in Multi-Regions
            • Two Firewall Networks
            • Central Egress in a Multi-Region Deployment
            • Distributed Egress in a Multi-Region Deployment
            • Ingress Protection via Aviatrix Transit FireNet
          • Use Cases for FireNet
          • Launch and Attach a Firewall Using Bootstrap Configuration
          • Create or Modify Connection Policies
            • Azure Spoke Subnet Groups for Attached Spoke Gateways
          • Attach a Spoke to a Transit FireNet
          • Aviatrix Transit FireNet for AWS and Azure
        • Firewall Overview
          • Launch and Attach a Firewall within a FireNet
          • Disassociating or Deleting or a Firewall Association
          • Manage Firewall Attachments
          • Checking Firewall Health
          • Configure Palo Alto for AWS
          • Configure Palo Alto for Azure
          • Configure Palo Alto for GCP
          • Configure Palo Alto for OCI
          • Configure Panorama Firewall Manager for VM-Series
          • Configure FortiGate for AWS
          • Configure FortiGate for Azure
          • Configure FortiGate for GCP
          • Configure Check Point for AWS
          • Configure Check Point for Azure
          • Blocking Traffic from Countries using GeoBlocking
        • Defining SmartGroups
        • Creating WebGroups
        • Deploying a Public Subnet Filtering Gateway
      • Monitoring and Troubleshooting
          • Monitoring the Costs of your Business Units
          • Creating a Topology Filter
          • Filtering Your Topology by CSP Tags
        • Monitoring Traffic Flows
          • Monitoring Traffic Flows at the Network Level
          • Monitoring Traffic Flows at the Application Level
          • Monitoring Egress Traffic
          • Monitoring Latencies
          • Viewing Telemetry Data for Managed Resources
          • Monitoring Resource Utilization of Managed Resources
          • CoPilot API Authentication
        • Diagnostic Tools
          • Aviatrix CoPilot FAQs
          • Troubleshooting Application Connectivity Issues
          • Aviatrix Site-to-Cloud Connectivity Diagnostics
          • BGP Connection Diagnostics
        • Notifications (Alerts) about Network Events
          • Configuring Alerts
          • Viewing Alert Notifications
          • Resolving Alerts
          • Pausing Alerts
          • Global Network Health Alert
        • Monitoring your Network for TLS Vulnerabilities
        • Aviatrix Reports Reference
      • Platform Administration
          • Aviatrix Log Formats
          • AWS CloudWatch Integration
          • CoPilot Controller Security Settings
          • Controller Security Group Management
        • CoPilot SAML Authentication
        • CoPilot DNS Lookup Server Management
        • IPsec Tunnel Management
        • CoPilot Licensing and Add-On Feature Management
        • Platform Support Tools
        • CoPilot Backup and Restore
          • CoPilot Configuration Backup and Restore (AWS Only)
          • CoPilot Index Data Backup
        • Manage Your CoPilot Index
        • Migrating CoPilot Data
        • Deleting a CoPilot Instance
        • Managing Cloud Resources
        • Debugging Tools in CoPilot
          • FIPS 140-2 Module
      • Upgrading Aviatrix
          • Upgrade OpenVPN Users
          • Multiple-Version Upgrade for Controller and Gateways
            • Upgrade your Gateway Image
        • Verify Your Upgrade
        • Rollback the Gateway Software
      • CoPilot Release Notes
        • CoPilot Image Release Notes
  • CoPilot
Topics
    • Transit Network Segmentation Overview
    • ActiveMesh 2.0
    • Aviatrix High Performance Encryption for GCP
    • Aviatrix CloudN Hardware Appliance
    • S2C Case Study
    • Overlapping Network Connectivity Solutions
    • Site2Cloud Configurations with External Devices
    • AWS Network Limits and Limitations
    • AWS Transit Gateway Limits
    • Connect to Floating IP Addresses in Multiple AWS Availability Zones
    • Solving Overlapping Networks with Network Mapped IPsec
  • Aviatrix Transit Network on Azure Cloud
  • Extending Your Workloads to Public Cloud
Building Your Network About Aviatrix Multicloud Transit Network
Aviatrix
  • Docs
  • Support
  • Terms of Use
  • Legal Notice
  • Doc Feedback
