Connecting Edge Interfaces
Use the Advanced section to set the advanced gateway settings that apply.
If the Edge WAN connection to the Transit Gateway is over a private network, set this toggle to On. Leave it Off if the connection is over the public internet.
Ensure that Jumbo Frame is enabled on the Edge Gateway before you attach the Edge Gateway to the Transit Gateway. High Performance Encryption
Ensure that the Transit Gateway is created with High Performance Encryption enabled before you attach the Edge Gateway. Max Performance
Max Performance is set to On when High Performance Encryption is enabled for both the Transit and Edge Gateway.
In Number of Tunnels, enter the number of HPE tunnels to create. The number of tunnels depends on the Edge Gateway instance size:
small: 4 tunnels
medium: 8 tunnels
large and x-large: up to 50 tunnels
To attach the Edge Gateway to another Transit Gateway:
Click + Transit Gateway Attachment again.
From the Transit Gateway drop-down menu, select another Transit Gateway.
Provide the required information.
