Deleting a Highly Available Gateway Instance
In CoPilot:
Go to Cloud Fabric > Gateways > select the Transit Gateways or Spoke Gateways tab.
In the table, locate the gateway that you want to edit. Click the Edit icon on the right side of its row.
Scroll down to the Instances section.
In the table, locate the gateway instance that you want to delete. Click the Delete icon on the right side of its row.
