Deleting a Spoke Gateway
To delete a Spoke Gateway:
In CoPilot, go to Cloud Fabric > Gateways > Spoke Gateways tab.
In the table, locate the Spoke Gateway you want to delete and click the Delete icon on the right side of its row.
To delete the Spoke Gateway, confirm that you want to delete the selected Spoke Gateway and click Delete.
CoPilot deletes the Spoke Gateway and all its associated resources, which includes the high availability Spoke Gateways, Spoke-to-Spoke and Transit-to-Spoke attachments or peerings, and external connections.
To monitor the progress of this gateway deletion:
From the left sidebar menu, go to Monitor > Notifications > Tasks tab.
In the table, locate the delete task and click the arrow to expand the row. Depending on the gateway settings, the following states will display:
Delete gateway attachment
Delete HA gateway
Delete primary gateway
