Detaching a Spoke Gateway from a Transit Gateway
To detach a Spoke Gateway from a Transit Gateway:
In CoPilot, go to Cloud Fabric > Gateways > Spoke Gateways tab.
In the table, locate the Spoke Gateway you want to detach from the Transit Gateway and click the Manage Transit Gateway Attachment icon on the right side of its row.
From the Transit Gateway dropdown menu, click x next to the Transit Gateway you want to detach.
The Aviatrix Controller also instructs the Transit Gateway to stop advertising the Spoke VPC/VNet CIDR to VGW.
| The Spoke Gateway is not deleted. You can attach the gateway to a Transit Gateway again. |
