Editing a Spoke Gateway
Go to Cloud Fabric > Gateways > Spoke Gateways tab.
In the table, locate the Spoke Gateway you want to edit and click the Edit icon on the right side of its row.
You can also search by name in the Search field or click the Filter icon to filter the list based on your criteria.
To edit the Spoke Gateway, you can change the gateway’s instance size, add or delete a Transit Gateway attachment, and add or delete HA Spoke Gateways.
To change the instance size, from the Instance Size dropdown menu, select a new size.
To attach a Transit Gateway, from Attach To Transit Gateway dropdown, select a Transit Gateway to attach the Spoke Gateway.
To delete a Transit Gateway attachment, in Attach To Transit Gateway, click X next to the Transit Gateway that you want to delete.
To add a HA Spoke Gateway:
In the Instances section, click + Instance.
In the new row in the table, select a subnet in a different availability zone (AZ) from the primary Spoke Gateway.
Enter the Public IP address of the HA Spoke Gateway. (AWS only) Leave Public IP at Allocate New Static Public IP.
Repeat to add additional HA gateways.
To delete a HA Spoke Gateway, in the Instances table, click the Delete icon next to the HA gateway you want to delete.
You cannot change High Performance Encryption or BGP settings after the Spoke Gateway is launched. -
