Visualizing Your Network
As you build your Aviatrix Multicloud Transit Network architecture, Aviatrix CoPilot automatically draws its topology as a map in Networking > Topology. The topology map enables you to visualize your Aviatrix-managed network whether it is multicloud or single cloud. By clicking on a network construct in the map, you can view detailed properties about that construct. You can create custom topology filters so that you can view only the network constructs you want in the map. You can use the Replay tab to identify changes that recently occurred to constructs in your network and highlight those constructs in the map.
For more information about using the topology map, see Gaining Visibility into Your Network Topology.
