Enabling Gateway NAT Settings
Gateway Network Address Translation (NAT) feature enables Aviatrix Transit Gateway, Spoke Gateway, and Aviatrix Secure Edge Gateway to perform Source NAT (SNAT) and Destination (DNAT) functions.
You enable NAT functions after a gateway is created.
| NAT rules are not synchronized from the primary gateway to the HA gateway instances. You must configure NAT rules on the primary and HA gateway instances separately. |
Source NAT
Source NAT enables instances on private subnets in AWS, Azure, GCP, or OCI to access the Internet. When Source NAT is enabled, all route tables for private subnets in the VPC or VNet are programmed with a route entry that points the gateway as the target for route entry 0.0.0.0/0.
You can choose to Source NAT a single IP address or a range of IP addresses.
Single IP
Single IP applies only to Spoke Gateways. When Single IP is selected, the Spoke Gateway’s primary IP address is used as the source IP address for Source NAT function. This is the default mode when you enable Source NAT for a Spoke Gateway.
Customized SNAT
Customized SNAT enables you to set up rules that enable the gateway to translate the source IP address, of the packets it forwards to other networks, to a virtual address range.
You can configure up to 2000 SNAT rules per gateway.
| Multiple IP support is not available in CoPilot. To edit Multiple IPs, use Aviatrix Controller. |
Destination NAT
Destination NAT (DNAT) rules enable the gateway to translate the destination IP address, of the packets that it receives from other networks, to a virtual address range.
You can configure up to 2000 DNAT rules per gateway.
Enabling Gateway SNAT Settings
Go to Cloud Fabric > Gateways > Transit Gateways or Spoke Gateways tab.
In the table, select the gateway for which you want to enable SNAT and DNAT.
Click the gateway’s Settings tab.
In the Settings tab, expand the Network Address Translation (NAT) section.
Use the toggle switch to turn Source NAT On.
(Spoke Gateway only) Select one of the following:
Single IP: Uses the Spoke Gateway’s primary IP address as the source IP address for Source NAT function.
Customized SNAT: Enables you to set up rules that enable the gateway to translate the source IP address to a virtual address range.
If you select Customized SNAT, continue to next step.
From the Instance dropdown menu, select either the primary or the high availability (HA) gateway to set up Source NAT for that gateway.
NAT rules are not synchronized from the primary gateway to the HA gateway instances. You must configure NAT rules on the primary and HA gateway instances separately. -
To add a translation rule, click + Rule.
Set up Source NAT Rule.
You can configure the following parameters to set up SNAT rules to meet your requirement.
Parameter Description Src CIDR
The source IP address range where the rule applies. When left blank, this field is not used.
Src PORT
The source port where the rule applies. When left blank, this field is not used.
Dst CIDR
The destination IP address range where the rule applies. When left blank, this field is not used and a default route 0.0.0.0/0 pointing to Aviatrix Gateway will be programmed into cloud platform routing table.
Dst PORT
The destination port where the rule applies. When left blank, this field is not used.
Protocol
The destination port protocol where the rule applies. When left blank, this field is not used.
Connection
The output connection where the rule applies. When left blank, this field is not used.
Mark
The tag or mark of a TCP session where the rule applies. When left blank, this field is not used.
SNAT IPs
The changed source IP address when all specified qualifier conditions meet. When left blank, this field is not used. One of the rule fields must be specified for this rule to take effect. Multiple translated source IP addresses are supported, they are specified as a range, for example, 100.100.1.5 - 100.100.1.10
SNAT Port
The changed source port when all specified qualifier conditions meet. When left blank, this field is not used. One of the rule fields must be specified for this rule to take effect.
Apply Route Entry
This is an option to program the route entry "DST CIDR pointing to Aviatrix Gateway" into cloud platform routing table.
Exclude Route Table
This field specifies which VPC private route table will not be programmed with the default route entry. You can combine this with Apply Route Entry enabled.
Repeat the steps above to add additional rules.
Enabling Gateway DNAT Settings
Use the toggle switch to turn Destination NAT On.
Set up Destination NAT Rule.
You can configure the following parameters to set up DNAT rules to meet your requirement.
Src PORT
The source port that the rule applies. When left blank, this field is not used.
Dst CIDR
The destination IP address range where the rule applies. When left blank, this field is not used and a default route 0.0.0.0/0 pointing to Aviatrix Gateway will be programmed into the cloud platform routing table.
Dst PORT
Protocol
Connection
Mark
The tag or mark of a TCP session when all conditions are mee. When left blank, this field is not used.
DNAT IPs
The translated destination IP address when all the specified conditions are met. When left blank, this field is not used. One of the rule field must be specified for this rule to take effect. Multiple translated source IP addresses are supported, they are specified as a range, for example, 100.101.2.5 - 100.101.2.10
DNAT Port
The translated destination port when all the specified conditions meet. When left blank, this field is not used. One of the rule field must be specified for this rule to take effect.
Apply Route Entry
This is an option to program the route entry "DST CIDR pointing to Aviatrix Gateway" into the cloud platform routing table.
Exclude Route Table
