Creating TGW Connects
AWS TGW Connect enables you to connect your AWS TGW underlay to your Network Virtual Appliance (NVA) overlay using a GRE tunnel. This connection offers more bandwidth than an IPSec tunnel.
Refer to the following AWS articles for information about the attachments types involved (Transit Gateway Connect attachment and Transit Gateway Connect peer):
To create a TGW Connect in Aviatrix CoPilot:
Go to Aviatrix CoPilot > Networking > Connectivity > AWS TGW tab > select the AWS TGW > select the TGW Connection tab.
Click + TGW Connection Attachment.
Enter the following information:
| Setting | Value |
Name |
Enter a name for the connection. |
Transport Attachment |
Select VPC to use a VPC or AWS Direct Connect to use AWS Direct Connect. |
Transport VPC or AWS Direct Connect |
Network Domain |
Click on the dropdown menu and select a Network Domain. |
The TGW Connect is created. To view the task’s progress, go to Monitoring > Notifications > select the Tasks tab.
If you have the same prefix propagated into your TGW route table coming from VPN, Direct Connect, and Transit Gateway Connect attachments, AWS evaluates the best path in the following order:
Priority 1 – Direct Connect Gateway attachment
Priority 2 – Transit Gateway Connect attachment
Priority 3 – VPN attachment
