Transit Gateway to Cisco ASA over the Internet Workflow
In CoPilot, navigate to Cloud Fabric > Gateways > Transit Gateways.
Create a Transit gateway that will connect to the Cisco ASA.
To connect the Transit VPC gateway to the Cisco ASA, navigate to Networking > Connectivity > External Connections (S2C) and follow these instructions.
Ensure that your Cisco ASA is configured based on the information in the downloaded file. The following is a sample configuration based on the external connection configuration above.
The tunnel IP addresses are configured accordingly with the configuration file downloaded above. -
After configuring the Cisco ASA, in CoPilot navigate to Diagnostics > Cloud Routes > External Connections to confirm that the tunnel status has changed from Down to Up.
Navigate to Diagnostics > Cloud Routes > BGP Info tab to verify the BGP routes.
