Before applying Distributed Cloud Firewall:
Your version of CoPilot must be 2.0 or greater.
Your version of Aviatrix Controller must be 6.7 or greater.
Gateways must have their image updated to version 6.7 or greater.
Network reachability should be configured between the VPCs that contain applications that require connectivity. You configure network reachability using Connected Transit/MCNS.
Enable Egress on the Spoke Gateways used in
If you plan to use cloud tags in your SmartGroups, Cloud resources must be tagged appropriately.
You must have already created WebGroups, if you want to use them in your Distributed Cloud Firewall configuration.
